Everything fit good so its sand sand sand sand sand time! Prepping for later upholstery, I still have to finish all the other pieces and fit them correctly before I go and get that done.
I will get back to the under dash part because theres alotttt that
goes into fitting these pieces and Im still working on it
JM Exclusive - Car PCs, Custom Fabrications, Mods and More JM Exclusive Facebook
12inch touchscreen CAR PC build...Multiple XBOX360s...Tvs Galore..Touchscreen Speedometer...JM Exclusive Youtube http://www.youtube.com/jkamakaze
Trunk/Wiring:
No as i said before, mycar has been a labrat for me learning to install. So opening it up completely the wiring looked Spidermans home. (HAVE A LOOK)
Starting the build on the trunk involved having to rewire the car
beforehand since I was going to hide a large majority in the spare
tire well. Every line that I planned to modify on relocated had to be
done at this ground stage. I have main junction points throughout the
car. This makes it easier to troubleshoot lines without tearing
everything apart or guessing what’s what if something were to happen.
My RFID Keyless Ignition relay bank and fuse box are all located in
this area along with my Kinetik Battery. Since Im trying to save max
trunk space I planned to put one of my amps in here as well (oh not to
mention the crossovers for my front speakers)
Now I def wanted to get rid of the box that the Kicker L5 sub came in and
do my own fiberglass box (save more room). I already had a previously
installed Xbox 360 on the left side so it was only natural to take up
the opposite corner.
Masked that corner off and laid down my resin/fiberglass to make the
mold. From the mold I built the frame for my kicker. Took me awhile to
figure the best position but I chose it to face the xbox enclosure to
keep a solid flow between all the pieces.
Wrapped the frame with fleece and soaked in resin and applied a couple of layers of fiberglass
Now to turn my attention to the xbox enclosure……(sigh) well looking at
the original outrageous NOOB fiberglass setup I had before, well it
was time to trash the entire thing and start fresh. It had no frame
and the shape of it was ridiculous looking. But it worked and had some
elements that I really did want to save.
Old Install XBOX Pics years ago (Dont laugh i was learning, just not afraid to show my progess):
Ok so now on to the new stuff..... now before i did say that i wanted to save some old of the features i did like....
For one, I made the fiberglass foundation for it right next to the
rollover vent, I glued a LARGE 4-5” PC Fan that points directly to the
vent and out the car through the rear bumper (didn’t want to lose
that, worked amazing for keeping the XBOX ventilated and cool even in
hot summers).
I also had a see thru DVD drive that I made myself out
of plexiglass, that was hard as hell to get right the first time so I
didnt want to lose that.
The idea of modding my xbox for disc-less play also came to mind, but
thought it would be a lot of work/testing. If I wanted to do that, I
can choose to mod it later after the car is done. I probably changed
ideas on the enclosure 4-5 times so im not even gonna bore you with
the ones that didn’t make the cut. Definitely wanted the guts shown,
wanted to keep the PC Fan and had to be easily removable.
So I came up with this enclosure and the plexiglass window can slide
out for easy unscrewing, then a cover piece to install/remove the
whole thing.
The xbox itself is a Regular xbox motherboard with Elite heatsinks on
the CPU and GPU. I added a purple LED fan to the top of the heatsinks
to aid the stock exhaust fans with cooling and air flow direction
towards the Rollover vent fan. I soldered wires to extend for a
pushbutton switch to turn on/eject the XBOX discs and extended both
cables to the disc drive to put the disc drive up front where I can
actually reach it.
Now as for the trunk I had to remaining issues to handle. Originally I
made this weird looking amp rack that would sit on the floor of the
trunk and hold my remaining Evolution amp and a headrest LCD I had
sitting in the attic. After building and mounting everything, I felt
it looked stupid and confusing. So I SCRAPPED it (more fiberglass
sacrificed for the sake of learning).
EWWWWWWWWW :(
I thought long and hard and thought it would be more beneficial if I
went “simple”. I decided to hide the second amp as well and make a
small ramp.
The floor of the trunk would be two pieces. The rear piece
that ramped down would be stationary and the front piece, because of
chance, fell right over the tire well, so that piece can be unscrewed
and removed for QUICK ACCESS to Kicker AMP, fuseboxes and all the
other wiring. I was in love.
Customized and functions great for daily
driver, doing it this way gave me a trunk, something I haven’t had in
years since I purchased my hugeee box from Kicker.
that L5 enclosure is sick, looks like it blends real nicely.
tuned in for sure :popcorn:
