Nssuits Posted November 12, 2012 Report Posted November 12, 2012 I need some help I have a brand new 13.5 jl w7 and a 1000/1v2 amp I have no clue what to do for a box or how to build what I need I want a box that will hit hard but still sound pretty good any help?
ZachG Posted November 12, 2012 Report Posted November 12, 2012 Post your max dimensions and the type of vehicle 1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
Nssuits Posted November 12, 2012 Author Report Posted November 12, 2012 37 ish inches long by 27 deepan the. As tall as we need the top of my trunk so over 34 inches. I drive a 95 vw golf
Joe X Posted November 12, 2012 Report Posted November 12, 2012 So here is a suggestion: Enclosure Specifications: Fb = 32 Hz Vb = 2.5 ft^3 External Height = 16 in External Width = 34 in External Depth = 17 in Port Width = 3 1/4 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Top & Bottom (3 parts) = 34 x 17 Left & Right Sides = Side 1 = 15 1/2 x 13 3/4 Side 2 = 16 1/4 x 13 3/4 Front = 30 x 13 3/4 Back = 34 x 13 3/4 L Port Internal Assembly Parts: Front to Back = 12 1/4 x 13 3/4 Extension = 22 x 13 3/4 Assembly guide (generic dimensions): Any questions, let me know.
SCS_Audio Posted November 13, 2012 Report Posted November 13, 2012 W7's like big boxes. The bigger the better for them IMO. I had a 13W7 in a 5 cube box in my trunk with 2 slot ports. Sounded good and got loud. If you could get to 4 cubes after displacement and tune to around 32 as suggested by JoeX that would be good. WIth only 1000 watts on that 13, no box will be too big. With mine in a 5 cube box, I had a Orion 2500D on it at 0.75 ohm. A larger box will be louder and more efficient. It will also help with lows (35 and below). 2012 North American Street Stock Runner-up - 150.9 on 1800 clamped watts (Teammate)2013 dB Drag Street Trunk World Champion - 153.9 on 3200 clamped Watts (Teammate)2013 MECA Trunk 1 World Champion - 152.8 Headrest (Teammate)2013 MECA Park & Pound 2 World Champion - 130.6 (Teammate)Checkout our build and videos !! : ) 150+ Trunk Build Log itsgordy1 youtube channel (click for Hairtricks)Smith's Custom SeatsMartinsburg, PA (Second Skin Dealer)
Nssuits Posted November 13, 2012 Author Report Posted November 13, 2012 What would be the differnce of running a 500/1 instead of the 1000 because I have a 500/1 1 as now and working at 1000 would the whole box change or would it be ok box for both 1000 and 500
Nssuits Posted November 13, 2012 Author Report Posted November 13, 2012 And would it be ok to build it with 1 inch think wood or should I for sure go with 3/4
kalilac619 Posted November 13, 2012 Report Posted November 13, 2012 W7's like big boxes. The bigger the better for them IMO. I had a 13W7 in a 5 cube box in my trunk with 2 slot ports. Sounded good and got loud. If you could get to 4 cubes after displacement and tune to around 32 as suggested by JoeX that would be good. WIth only 1000 watts on that 13, no box will be too big. With mine in a 5 cube box, I had a Orion 2500D on it at 0.75 ohm. A larger box will be louder and more efficient. It will also help with lows (35 and below). totally agree specs on these are 2.3 cuft net tuned to 32hz built it and it sucked currently have 2 13w7 in 7.4cuft net which is 3.7 cubes each tuned at 30hz with an F3 of 25hz and they pound plays within a db from 30hz to 65ish hz 2000 Suburban 6 runs of 2/0 12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door 475ah of yin long LTOs Triple 370 Amp Autotech Alts mids amps 2 Crescendo Skyway 3ks compreesion horn amp crossfire 800.4 Tweet amp Crossfire 2000.4 sub amp: 4 Crossfire XT 8ks Subs: 8 18 in Crossfires in a 4th order Best Scores at events… 163.5@38hz DBdrag sealed on the dash… 164.3 outlaw…162.9 Meca headrest
SCS_Audio Posted November 14, 2012 Report Posted November 14, 2012 What would be the differnce of running a 500/1 instead of the 1000 because I have a 500/1 1 as now and working at 1000 would the whole box change or would it be ok box for both 1000 and 500 The difference would be a 500/1 would hardly move that thing lol. I did have 2 JL 1000/1 on mine for a while. One on each coil. A single 1000/1 is enough to get this sub going, but no where near it's full potential. As your power increases, the general rule is you need to decrease your box volume. This is because a larger box has less control over the excursion of the sub. In your case, a single 1000/1 will have no problems even in a 5+ cube box. The X-mech of those things is pretty hard to hit. You just need to set your subsonic filter if you are scared of making it tap. 2012 North American Street Stock Runner-up - 150.9 on 1800 clamped watts (Teammate)2013 dB Drag Street Trunk World Champion - 153.9 on 3200 clamped Watts (Teammate)2013 MECA Trunk 1 World Champion - 152.8 Headrest (Teammate)2013 MECA Park & Pound 2 World Champion - 130.6 (Teammate)Checkout our build and videos !! : ) 150+ Trunk Build Log itsgordy1 youtube channel (click for Hairtricks)Smith's Custom SeatsMartinsburg, PA (Second Skin Dealer)
