Active wiring
OrzechNJ
I think the easy solution to your problem is to flip the switch in the crossovers that came with your t2's to the bi-amp setting. run one channel to the tweeter in and one channel to the woofer in. then hook the tweeter to the tweeter out and woofer to the woofer out. Then you can dial back the gain on the channel your tweeter is hooked to. Also, the crossover has a -3db setting or something like that.
it got "+2 0 -2" setting
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
yes
the other thing is that the T2's have is "bi amp option" I kinda know what its for but not sure if its worth to use..
the bi-amp feature would let you set the levels of the tweets and the mids separately. but you would need a 4 channel amp to do it.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
you could run 4 mids and 4 tweets of the t600.4 so of course it can handle 2 mids and 2 tweets.
i like the bi-amp idea to though. i think that would work out great.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
he is talking about using the t600.4, so yes he would be using a 4 channel amp.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
ahem* t600-4
i do have 4 channel amp / t600-4
tweeters dont need too much power to get loud im more consider about the mids..
the other thing is if I use the bi-amp option / shoud I switch the setting on the amp on 2 channel ?
I dont wanna my tweeters to play the front stage and mids the "rear" stage .. i hope u know what i mean
  • Who's Online   0 Members, 0 Anonymous, 922 Guests (See full list)
