Active wiring
OrzechNJ
o, hell yes. Phht, just run a set of rca's from your h/u front/rear each. run front to front input, rear to rear input. and use the headunit to set crossover points. run the amp is full pass.
you are ok wit using all four outputs on your amp right?
yea since Im using them now .. lol.. I gonan wire tweeters to front and mids to back.. I just wanna play them only left/ right channels not surround as it was mentioned before
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
Unreal......
Set your amp to 2 channel input mode.
Run front RCA cable from radio to amp.
You now have a rear RCA available for a rear amp.
Set both internal amps to 100hz high pass
Do not set your passive x-over to bi amp
Run each channel to one set of components. You will end up with one tweet, mid and passive on each channel.
If the resets are to high set the passive to -x db down.
If the tweeds are still to bright turn the treble down on the deck
All this talk about series parallel 8ohm 32ohm is kinda much. Don't try and reinvent the wheel.
Rolex you sicken me.
Just let me finish my pie
~ Juice
Unreal......
thats how i run it now and like i said before the tweeters are way louder than mids / i was messing with the HU a lot and didnt came out with as good effect as I wanted
why not? i was still under the impression he was only running a single component set. but he has the headunit for active so why not use it?
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
I don't know if I'm more pist at the fact he didn't mention that pioneer earlier or the fact no one asked!
Haha
I know right, i agree i was overthinking it, so i figured i would just see what he was running. I almost fell out of my chair laughing when he said 80prs.
  • Who's Online   0 Members, 0 Anonymous, 1111 Guests (See full list)
