01 Hyundai Tiburon | Fuse/Wiring problems.
yes, and replace the ground with 4gauge and get an anl fuse holder with a 200amp fuse. keep the wire you have though, assuming its 8gauge you can use it as speaker wires for your subs or for a small 4 channel amp.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
What size amp?
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
Alright, so take the current power wire out and swap that with 1/0. then get a Fused Distribution block 1 0 Input, 2 4 outputs? then wires the amps to that?
yes and if you upgrade later you will not need to change the wire
get a ground distro block and do the same as well it will do nothing but help your system
The fuse says "AGU60A" sorry for the confusion.
and here is the problem. if they did the install or recommended the products and the fuse size/holder swat them across the back of their heads and tell them to replace everything with the proper wiring and fusing. if they gave you advice and told you that wiring and fuse would work fine they put you and anyone else in the car at risk.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
still assuming here but if its a t1500.1bd or bdcp he would be needing more power supply. even if its just a t100.1 he would actually. so wouldnt another battery in the trunk with 1/0 from front to rear batt and 4gauge from batt to amp with amp grounded to the batt be the better route. of course all depending on the depth of his pocket.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Well if its a 500d or something then he just needs to go up to a 80 or 100 amp in that holder , but I don't see what size amp he has, only that its a Rockford.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
every one of those connections is a horrible connection. your underhood fuse is blowing right? Its an agu type fuse they dont come bigger than 80 amps
good call, didn't think of that. get a anl fuse holder and a 200amp anl fuse.
still though what amp do you have?
I have the Rockford Fosgate T1500-1bdCP
My trip to Meades shop - http://www.stevemeadedesigns.com/board/topic/172904-could-i-come-for-a-visit/
My vid at Meades shop - http://www.youtube.com/watch?v=YxinD-xwWWo
Had an amazing time bro! Die hard Meade fan!
-- My System -- 2001 Hyundai Tiburon --
(1) Rockford Fosgate 1500.1bdCP
(1) Rockford Fosgate 360.3
(1) Pioneer GM-D9500F
(1) Optima Yellow Top D34/78
(2) Pioneer TS-W3002D - 1000W RMS 12's
(1) iPhone 5s - 32gb White
(1) iPad Mini - 16gb Black ( 24/7 Headunit )
-- Wanted Upgrades --
(2) SP4 (15's or 18's)
(1) BC5500
(1) Mechman 320 amp Alt
(4) Optima Yellow Top D34/78
(1) Big 3 Upgrade Kit
Fix my other T1500.1bdcp
(1) BC5500
he has a second amp that LONG run of CCA 4 guage is only good for ABOUT 800 watts even with a bigger fuse his current draw and voltage drop in that line is gonna be horrible
or what he's runing 4/2/1 ohm?
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
