94jettameowpsst Posted November 14, 2012 Report Posted November 14, 2012 How do you remove clipping from songs without doing it one cycle at a damn time?? 150.1 @ 38hz142.3 @ 20hz (windows down)Only 2 batteries
94jettameowpsst Posted November 14, 2012 Author Report Posted November 14, 2012 Figured it out, never mind 150.1 @ 38hz142.3 @ 20hz (windows down)Only 2 batteries
Noel989 Posted November 14, 2012 Report Posted November 14, 2012 You can't remove clipping unless you have the studio file if its a mixing if its the sample then you would have redo the waves Your just making the wave smaller. I can make a track that shows no clipping but be distorted like shit Build Log - http://www.stevemead...-cruiser-el-pt/
94jettameowpsst Posted November 14, 2012 Author Report Posted November 14, 2012 Didn't know that, here I thought I was making it better by decreasing amplification bc when u chek for clipping it shows none 150.1 @ 38hz142.3 @ 20hz (windows down)Only 2 batteries
SnowDrifter Posted November 14, 2012 Report Posted November 14, 2012 Nope. Clipping is in the waveform. Simply reducing the level only results in quieter clipping - but no change in how much it clips ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Noel989 Posted November 14, 2012 Report Posted November 14, 2012 My friend has a studio so I've learn a lot from being their. sometimes all the waves (instruments/samples) Are clean and on the master track theirs several clips so we just lower the violume and viseverssa So if what ever was recorded is dirty is going to stay dirty Yea you can make the wave smaller like you want to do audacity and remove the red marks but all you did was make the wave smaller and smaller wave is less volume less volume harder to hear Build Log - http://www.stevemead...-cruiser-el-pt/
94jettameowpsst Posted November 14, 2012 Author Report Posted November 14, 2012 So does the song clipping actually effect how it plays? Because 99% of the songs I opened up apparently clip which I had NO idea. 150.1 @ 38hz142.3 @ 20hz (windows down)Only 2 batteries
Azagtoth502 Posted November 14, 2012 Report Posted November 14, 2012 A lot of modern music has mild clipping...though annoying, it shouldn't harm the speakers. pa-pa-platypus sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
Noel989 Posted November 14, 2012 Report Posted November 14, 2012 So does the song clipping actually effect how it plays? Because 99% of the songs I opened up apparently clip which I had NO idea. Minor clip here and there are alright their so small and short(as in time) that is hard to hear and won't cause anything can you play them Absolutely after you set your gains and xovers correctly but just cause it it's set up to x volume doesnt mean you'll be able to go to max volume on all songs And if there's a song that's really dirty you still can play just at lower volumes But don't worry to much about it as long as you kno the limits to your system you can play anything clip or not Build Log - http://www.stevemead...-cruiser-el-pt/
Decaf Posted November 14, 2012 Report Posted November 14, 2012 Reducing the amplification is analogous to turning the volume down while playing the original track One cannot remove clipping, but you can lower the amplitude of the offensive frequencies... but meh Red on audacity means it has reached 0db or surpassed it, any frequency from 0-40000hz could have done that and the 80-20hz are the frequencies that you need to worry about for sub bass, worry not about if a song is red, but whether the waveform is clean without plateauing or large flat spots or sawtooth/ramp waveforms. If you have .00000000000000001seconds where a song touches or goes past the data "limit" it will turn red, so its not exactly a precise measurement of what will actually cause damage on a stereo system
