XS Power
The alternator amperage doesn't have anything to do with deciding how many batteries you need. The alternator will only put out what charge voltage the battery and system needs and requires.
The pull of the system decides what alternator and battery power you need.
6000rms for comps you will need more than 1 D3100 and either of those alts to keep the voltage up.
Thanks for that Nathan,
I was just wondering what happens to the extra power from the alt if the battery was fully charged. was guessing that the the alt gets all the load put onto itself, Or is the alt not always charging the battery unless the battery has dropped voltage?
the electricity knows where to go. let it do its thing. for 1500rms the alt and d3100 is more than enough. for 6k get another d3100 and you is fine. yuou could probably pull it off with 1 D3100 and the alt for a burp but dont try bumpin
Edited by Bump4life
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
I have a yellow top battery, should i use this as my starter and put the d3100 in the boot, or d3100 as starter?
