CarbonCone Posted November 15, 2012 Report Posted November 15, 2012 Just wondering if an single D3100 would be okay with a single 320amp alt, or would I need another battery? or would a 240amp alt be better option, Dont really want to run another battery if possible. Quote
corona_jeff Posted November 15, 2012 Report Posted November 15, 2012 What are you trying to run? Quote
CarbonCone Posted November 15, 2012 Author Report Posted November 15, 2012 What are you trying to run? What are you trying to run? Only 1500rms daily and 6000rms comps Quote
Nathan @ XSpower Posted November 15, 2012 Report Posted November 15, 2012 The alternator amperage doesn't have anything to do with deciding how many batteries you need. The alternator will only put out what charge voltage the battery and system needs and requires. The pull of the system decides what alternator and battery power you need. 6000rms for comps you will need more than 1 D3100 and either of those alts to keep the voltage up. Quote
CarbonCone Posted November 15, 2012 Author Report Posted November 15, 2012 Thanks for that Nathan, I was just wondering what happens to the extra power from the alt if the battery was fully charged. was guessing that the the alt gets all the load put onto itself, Or is the alt not always charging the battery unless the battery has dropped voltage? Quote
Bump4life Posted November 15, 2012 Report Posted November 15, 2012 (edited) Thanks for that Nathan, I was just wondering what happens to the extra power from the alt if the battery was fully charged. was guessing that the the alt gets all the load put onto itself, Or is the alt not always charging the battery unless the battery has dropped voltage? the electricity knows where to go. let it do its thing. for 1500rms the alt and d3100 is more than enough. for 6k get another d3100 and you is fine. yuou could probably pull it off with 1 D3100 and the alt for a burp but dont try bumpin Edited November 15, 2012 by Bump4life Quote Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
CarbonCone Posted November 16, 2012 Author Report Posted November 16, 2012 Thanks for that Nathan, I was just wondering what happens to the extra power from the alt if the battery was fully charged. was guessing that the the alt gets all the load put onto itself, Or is the alt not always charging the battery unless the battery has dropped voltage? the electricity knows where to go. let it do its thing. for 1500rms the alt and d3100 is more than enough. for 6k get another d3100 and you is fine. yuou could probably pull it off with 1 D3100 and the alt for a burp but dont try bumpin I have a yellow top battery, should i use this as my starter and put the d3100 in the boot, or d3100 as starter? Quote
Nathan @ XSpower Posted November 16, 2012 Report Posted November 16, 2012 Test it out with your installation. What works for someone else may not work for you. Car audio is about testing and seeing what works for you. Quote
