stereo for girlfriends car for christmas
I am in the process of putting together a system for a christmas present. It will consist of alpine cde-hd138bt for the head unit. Then for the speakers i will be using rockford fosgate t1652-s for the front doors and t152-s for the rear doors. For the sub I am using a sundown sa-8v2 d2. I am going to run rockford fosgate pbr500x1 to the sub running 1 ohm. I am going to use a pbr300x4 for the component speakers. Should I run them passive or get another pbr300x4 and run all the mids and highs active. I want the best sound in her car.
If you have the $ to burn and are willing to go through the headaches of tunning with x-over points and such that come along with an active set up there is nothing stopping you.
The fact is though that unless you are going to compete or you and your GF are Audiophiles the odds are neither of you will see that great of a difference that justifies the added expense and hassle of going active.
welcome to SMD, now post pics of said GF
Rolex you sicken me.
Just let me finish my pie
~ Juice
I'm with rolex on this one. Save the trouble of active. Its someting you can upgrade to later if you want. Plenty of very nice systems out there run passive. Besides, who's to say you won't be very sastified with passive untill you run it for awhile. Get some serious listening time in then decide if its missing something.
Oh and pix of said gf :ninja:
Also since I am just running 2 pbr amps. Should I run a power wire for each from the front or run a 4 awg and the hit a distribution block. Then should I put them in a somewhat enclosed area and put a fan on them to keep them at a steady temperature.
Dont over complicate it. Run a good 4 gauge wire to a two way distribution block.
Toss a 100 amp fuse by the battery, an 80 amp fuse feeding an 8 gauge to the 500x1 and a 30 amp fuse feeding a 10 gauge to the 300x4.
the 80+30 = 110 but with a 100 up front IF both amps were ever to draw max power you would be safe. better to under cut the amperage for safety rhather than over fuse the system.
And as far as cooling goes, again..... these amps will be just fine.
If they needed cooling fosgate would have put a fan in them and it's not like either are a 200 amp current draw monsters.
this is a straight forward install tha should take a nice quiet weekend. And completeing thsi project should hamper you from those pix!
~ Juice
  • Who's Online   0 Members, 0 Anonymous, 1190 Guests (See full list)
