BassJunkie Posted November 17, 2012 Report Share Posted November 17, 2012 As the title states has anyone tried to install the Term-Lab software on Windows 8 yet? I'll find out tomorrow if it works or not but would just like to know what to expect. 1986 C20 Suburban 9 American Bass XFL 15's B2 M1MKII 14v XS Power Batteries Maxwell Caps Acoustical energy is free. Electrical energy is not you havent lived until you've hit a screw with a router. Link to comment Share on other sites More sharing options...
BassJunkie Posted November 18, 2012 Author Report Share Posted November 18, 2012 Just an FYI. It does not work with windows 8. 1986 C20 Suburban 9 American Bass XFL 15's B2 M1MKII 14v XS Power Batteries Maxwell Caps Acoustical energy is free. Electrical energy is not you havent lived until you've hit a screw with a router. Link to comment Share on other sites More sharing options...
odsound Posted January 13, 2013 Report Share Posted January 13, 2013 did u get it to work?im having that same issue on my windows 8 vehicle-02 toyota celicawoofers-groundshaker g-s1 10" woofersamp-SUNDOWNAUDIO SAZ 3500battery-1 C&D battery Link to comment Share on other sites More sharing options...
MICEuk Posted January 27, 2013 Report Share Posted January 27, 2013 I too am trying to get this to work, i can get instcal to run, it to see the sensor in it, the Termlab software to install and open ok... But can not get it to do a DB Reading! anyone else got it to work? Mike MICEuk MICEuk's Website! Volvo 850 T5 Turbo Estate 4 15inch subs......Build in progress! SO WHAT IF I GO DEAF I CAN STILL FEEL THE BASS!!! Link to comment Share on other sites More sharing options...
odsound Posted February 1, 2013 Report Share Posted February 1, 2013 i have sent wayne three emails and no response and sent him a fourth email saying i give up and asking how much a second sensor would cost me got a message the next day saying $200 for the sensor and no word on how to get my software to work vehicle-02 toyota celicawoofers-groundshaker g-s1 10" woofersamp-SUNDOWNAUDIO SAZ 3500battery-1 C&D battery Link to comment Share on other sites More sharing options...
STEvil Posted February 1, 2013 Report Share Posted February 1, 2013 using compatability mode guys? MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed. Link to comment Share on other sites More sharing options...
odsound Posted February 1, 2013 Report Share Posted February 1, 2013 using compatability mode guys? i did tried windows 7 vista and xp and no luck vehicle-02 toyota celicawoofers-groundshaker g-s1 10" woofersamp-SUNDOWNAUDIO SAZ 3500battery-1 C&D battery Link to comment Share on other sites More sharing options...
kickass audio Posted February 1, 2013 Report Share Posted February 1, 2013 maybe you should run it as a VM host on the computer. There are free versions like microsofts VM host you can download and load the VM up with XP or 7 if it worked on 7. Idk if it would see the termlab but i dont see why it wouldnt through a virtual machine. Its worth a shot. I don't have a TL so i cant tell you that this will work for sure but its worth a shot for everyone who does have one and is somewhat knowledgeable with computers to give it a shot. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress Link to comment Share on other sites More sharing options...
STEvil Posted February 1, 2013 Report Share Posted February 1, 2013 Windows 8 may see the termlab as an audio source and be highjacking the audio stream. Check the sound control panel to see that its not muted and alternatively check if you can run the input in ASIO mode. Alternately it may be the audio chipset is locked to 44.1 or 48khz input, or the drivers are defaulting you to this in the windows control panels. You should be able to adjust the setting in the audio control panel if its related to the issue.. http://www.circularlabs.com/forums/archive/index.php/t-325.html Also make sure you're running termlab.exe in admin mode. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed. Link to comment Share on other sites More sharing options...
BassJunkie Posted April 22, 2013 Author Report Share Posted April 22, 2013 Just an update. The new version of the term-lab software will work with windows 8, just tried it today. Didn't do anything special to it. Way better than using vmware and xp, which is what i was doing prior to the update. 1986 C20 Suburban 9 American Bass XFL 15's B2 M1MKII 14v XS Power Batteries Maxwell Caps Acoustical energy is free. Electrical energy is not you havent lived until you've hit a screw with a router. Link to comment Share on other sites More sharing options...
