USAFsound Posted November 19, 2012 Report Posted November 19, 2012 I'm running a kicker zxs1500.1 pushing two L7 12s....mistake number one, I know. My problem is I was playing at around 3/4 volume the other day and my subs got drastically quiter. I'm stuck. I can provide any other needed info I just don't know what to include. Thanks in advance guys.
revoracing247 Posted November 19, 2012 Report Posted November 19, 2012 have you checked all the obvious? like the fuses on the amp and in your amp wiring? and your sure they haven't just completely just turned off but they are just "quieter"? ~ If it was easy, everybody would be doing it ~
Shankkilla420 Posted November 19, 2012 Report Posted November 19, 2012 I'd bet money that one of your output wires crossed on your subs. Nothing wrong with the combo either btw, good shit if you set your gains right.
revoracing247 Posted November 19, 2012 Report Posted November 19, 2012 i guess you could of also accidentaly have knocked some leads off your voice coils and only be running one of the two or something. ~ If it was easy, everybody would be doing it ~
USAFsound Posted November 19, 2012 Author Report Posted November 19, 2012 I checked all my fuses and everything is good. I pulled both subs out of the box and confirmed they are working individually. @shankkilla420 could you elaborate?
USAFsound Posted November 19, 2012 Author Report Posted November 19, 2012 @revoracing247 any way to check voice coils?
REVOofRustler Posted November 19, 2012 Report Posted November 19, 2012 If you have a dmm, check the impedance of each coil to make sure they're ok. Also, push down on the cones and see if you can feel any scratching or rubbing. 2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant - Fi and Crescendo - Stock Bose System - http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota 136.4 Sealed @ 29hz 137.0 Drivers window open @ 26hz
FrontierGello Posted November 19, 2012 Report Posted November 19, 2012 If you have a dmm, check the impedance of each coil to make sure they're ok. Also, push down on the cones and see if you can feel any scratching or rubbing. I have a question bro. if the reading of the impedance is way too high does that mean the coils are touching the magnets? Nissan Frontier 10" Cadence Midbass 8" Cadnece Midrange Bullet tweets 2 Re audio Sxx 15 Subs Mechman 270a 2 Re XT4000deV3 mono 1600 rms 1 Re XT400deV3 Bridged 350x2 2 Cadence 175.4 Bridged 350x2 Audiomaxx and Stinger 0,4,8,12 awg wires Dynamat sound deadeners My Build Log: http://www.stevemead...__+1999 +nissan
USAFsound Posted November 19, 2012 Author Report Posted November 19, 2012 Will do. Do you think it could be a problem with the preamp on my head unit? The reason I ask is because I have also recently had some issues with the screen. It's a kenwood ddx 418. Just a theory I'm trying to get all my ducks in a row before I start checking everything.
