Why does my amp still cut out? Need help
I run an ma audio hk4000d for 2 dc level 4 XL 15s. It's at 2 ohms. Everything is run with 0 guage. I have the big 3 with 2 guage. Yet if its cold out my amp wants to cut out when I have high volume and or gain. And when I turn my head lights the whole way on you can here the amp turn off and on real quick. I have my main battery and 3 extra deca intimidators in the back. I don't know what else to upgrade to solve this. I also have a mechman 250a ho alt. any suggestions?
Hmm, based on everything your saying that you installed, it should run just fine. Have you bench tested the amp? There is a chance it's not in your wiring and in the amp itself.
^ x2. Start off with ensuring the amp is good.
Audio Build
Ride: 2002 Chevy Blazer 4 door
Head Unit: Pioneer deh-80prs
Subs: 4 DC Level 3 15's in a 4th order wall designed by Trent Choate and Jeff Smith
Subs Amp: AQ 3500.1 at wired at .5 (soon to be 2)
Mids/Highs Amp: Skar 85.4
Mids/Highs: Skar components
Electrical: Mechman 270 amp alt, 2 runs of Knu 0 gauge, XS Power d3400, 2 Deka Group 9a31
Build log : http://www.stevemeadedesigns.com/board/topic/167658-indianabasshead-blazer-dc-audio-4th-order-wall-build/
Perfomance Build
2003 Nissan 350z
Greddy Twin Turbo, 3" Test pipes with Borla high-flow cats, Crawford Performance Plenum, Greddy E-manage Ultimate ECU
Exedy Racing Clutch, Built Motor by Racing Innovations
Greddy Over-fender aero kit (1 of 20 ever made), 19" Racing Hart r5 pro wheels
466rwhp
Bike
2008 Midnight Blue Kawasaki ZX-14
Stretched 8" and lowered, Brocks Sidewinder exhaust, Power Commander 5
It happens more and more when the temp drops. Or if you have it very loud and hit the lights it shuts off til I turn it back down then I can turn it up again just not as much. It's fine with just my parking lights
Let's see,
How was your gain set.
Where is your ground for your amp? Batts?
Voltage drop? Those are current hungry bastards.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
Gain is set 3 up from min. I have ground and power to first back battery. That first battery runs to the other two back ones and then to the front. The front battery is the only one grounded. At idle the lowest drop I've seen is to 11.8 at full tilt. When driving the lowest is maybe 12.2. But with the lights on my voltage drops about .1 below average. I don't get it. It bumps fine when the amp warms up and lights are off.
  • Who's Online   0 Members, 0 Anonymous, 1193 Guests (See full list)
