Truconcept Posted November 23, 2012 Report Share Posted November 23, 2012 i have the same amp on subs not as good as his **actin bad like a kid at six flags** Link to comment Share on other sites More sharing options...
SnowDrifter Posted November 23, 2012 Report Share Posted November 23, 2012 So you are suggesting he risk feeding his subs what is pretty much a square wave? Sounds like a recipe for disaster. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Truconcept Posted November 23, 2012 Report Share Posted November 23, 2012 how much risk is it with 2 subs 4k peak ea, wired on an amp with 1700watts on its best day the guy probably cant tell if he has distortion cause the subs laugh at that amp **actin bad like a kid at six flags** Link to comment Share on other sites More sharing options...
SnowDrifter Posted November 23, 2012 Report Share Posted November 23, 2012 Since when does peak mean anything? Do you not know that you can blow subs on less than RMS power by sending them a clipped signal? Not to mention that it sounds like crap and it dumps a lot of heat into a cheap amp, risking blowing that as well. Plus the strain on his electrical. Not going to turn this into a multi-page pissing match. But I think you should refrain from giving "advice" that carries a high likelihood of breaking other people's equipment ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Truconcept Posted November 23, 2012 Report Share Posted November 23, 2012 ok thanks for the tip i just run it everyday (1yr+) that way on less then good subs so i felt confident **actin bad like a kid at six flags** Link to comment Share on other sites More sharing options...
akronjay Posted November 23, 2012 Report Share Posted November 23, 2012 So true snowdrifter lol 4 kicker ks 60 1"AMERICAN BASS DOMES RE DTS 80X2 AMERICAN BASS xd2000 2 OBSIDIAN 15D2 ALL KNU WIRING & RCA THE BIG THREE 1.5FARAD MASSIVE AUDIO CAP 2.0FARAD MASSIVE AUDIO CAP 98 JEEP CHEROKEE avic930 optima red top american bass sq2000 Link to comment Share on other sites More sharing options...
Noel989 Posted November 23, 2012 Report Share Posted November 23, 2012 ok thanks for the tip i just run it everyday (1yr+) that way on less then good subs so i felt confident Maybe nothing has happen cause you have low voltage from the preouts Build Log - http://www.stevemead...-cruiser-el-pt/ Link to comment Share on other sites More sharing options...
VictorFarias Posted November 23, 2012 Author Report Share Posted November 23, 2012 My set is running, o dont know how much volume o can use. The amp is 1700wrms 1ohm and the subs are in 1,5ohms Link to comment Share on other sites More sharing options...
Noel989 Posted November 23, 2012 Report Share Posted November 23, 2012 My set is running, o dont know how much volume o can use. The amp is 1700wrms 1ohm and the subs are in 1,5ohms You need an o-scope or dd-1 Build Log - http://www.stevemead...-cruiser-el-pt/ Link to comment Share on other sites More sharing options...
Guest Posted November 23, 2012 Report Share Posted November 23, 2012 LOL full gain what a joke. only reason you haven't fucked up your subs yet is because your preout voltage is so low that it doesn't even matter. Link to comment Share on other sites More sharing options...
