FI X series subwoofer sneak peek
Miguels
The X Series is back, and better than ever! New larger voice coil, now 3". Higher power handling, now rated at 750rms.
The X Series of subwoofers is our all around daily sub. We offer the BP option (a machined compression plug), for increased cooling and higher thermal powerhandling. A multilayer foam surround is attached to a fiber impregnated kraft pulp cone which helps keep things under control in high power applications. A 3" 4 layer aluminum voice coil yields 20mm of Xmax while keeping the motor force high. The X series will work in most enclosure types (sealed, ported, bandpass). Light weight and versatile, the X Series works in a variety of applications from incredibly detailed sound quality systems, to ground pounding multi sub monsters. It comes standard with a white Fi logo on a rigid pressed kraft cap with the option of our hard dustcap and choice of colored Fi logos.
Features:
X Series: 10”, 12”, and 15"
Dual 2 and Dual 4 Ohm
Cast basket
Wrap around gasket
Kraft pulp fiber reinforced cone
Single layer wide foam surround
Push terminals
Extra heavy lead wire
FEA optimized motor
3” diameter 4 layer coil
Single high grade magnet
Triple progressive spiders
Optional BP Cooling
X15 DUAL 2 | DUAL 4 Fs: 30.0 Hz | 30.0 Hz Re: 1.4 Ohms/coil | 2.8 Ohms/coil Qms: 7.48 | 7.48 Qes: .57 | .57 Qts: .53 | .53 Mms: 212g | 212g Cms: 0.00mm/N | 0.00mm/N Sd: 810cm^2 | 810cm^2 Vas: 121.1 l | 121.1 l Spl: 89.5dB 1W/1m | 89.5dB 1W/1m Bl: 14.01 N/A | 19.81 N/A Xmax: 20mm Rms: 750W Sealed box: 1.5-2.5 cuft Ported box: 3-5cuft @ 33Hz Sub OD: 15.625” Cut ID: 14.125” Mounting depth: 7.5” Displacement: 0.09cuft
  • Who's Online   1 Member, 0 Anonymous, 2255 Guests (See full list)
