teamSPB 2009 BMW 1 Series build - Ascendant, B2, Mosconi, Gladen
Got a 2009 BMW 118d to do an install in currently belonging to Sunny...his requirements were OEM integration to the stock BMW headunit, upgrade the component system in the car, add a pair of subs to enhance the low end response. Everything must look stock in the cabin, with a good looking boot build to show when at shows etc
The spec will be;
Mosconi 6to8 processor with OEM integration
Gladen Audio BMW 200 component kit - 3 way consisting of tweeters, midrange and under seat subs
Mosconi ONE 120.4 amplifier powering the components
2 x Ascendant Audio Chaos 10s in custom made ported box
B2 Audio Mono mkII 2200wrms amp
Let the build commence!
There were no tweeters present in the OEM sound system, so we had to order in BMW HK tweeter panels for the stock look
Gladen BMW 200 midrange speaker
Silk dome tweeter
Crossover
Heat shrinked connectors then insulation tapped over the wiring
Same with the other side...pic of the tweeter fitted
teamSPB
Under seat subs
OEM Sub vs Gladen 8
Shallow subs!
OEM enclosure
I was going to sound deaden these sub they really are solid and have no resonance or flex...especially considering they are bolted directly onto the floor!
Sub in
Passenger side had plent of change attached to it lol
Gladen BMW wiring harness
This allows you to add an external amplifer without the need to modify cabling or cut anything!
looking great so far! i am tuned in for this build so keep those pics coming bro :D
Follow my Tweet (Twitter)
Bass controller being ran into a cubby hole
Mosconi ONE 120.4
Unfortunately there isnt much space for the amps to sit unlike the E90s, so we had to put the amps on the top...which is no problem as the pretty panels will cover everything
Can just about make out the wiring loom ;)
Levelling up the boot build
