Need help on what home amp/plate/receiver ?
So I'm planning on getting 16 5" for mids . Either 8ohm or 4ohm . Whatever ohm load works better .
They are 25rms/ 50 watts each . So need around 400rms for those highs ....
Any suggestions ? I have nooo idea what to get ... Was thinking of running them on a home stereo for a bit until I decide in what home plate amp receiver
And for subs /woofers will be down the road .
Your not going to get that much power out of a home theatre amp....
Ether a plate amp or a rack style amp. They can be cheap and effective.
Plus once you get a couple of them they look fucking awesome!!!
Edit: just realized I didn't answer your question at all, but what I would do if it was my money is to get a rack mountable amp (qsc,crown, etc) as they will sound a lot better and look alot nicer on show then a rack amp
PSN: Rcp_soundz
Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at.
I'll stick a 300 amp fuse in a potato and sell it to you for $2k.
1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
I wish I can get a crown , but I'm more in a budget side .
I'm getting the 16- 5" for less than 200$...
So whatever is the cheapest and most effective, per say like a hifonics brz/bxi In car audio . Does rated and gets the job done but its a budget amp . Would want but can't afford the zapco/audison/focal/etc of home audio but can't afford it .
I really don't have any help for your small highs amp- other than what RCP said, why not run them through your reciever...
BUT- on the sub amp: I recommend BASH. I've got a BASH 500 running 4 12"s in the living room. HAHA!! It gets down- and everything is running at so low a level- it has crazy headroom.
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
I'd second crown if you were able to afford it:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=245-500
A little less expensive, not a bad amp. Less power and quality than Crown but your speakers should get pretty loud:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=248-749
And here's your cheap option, 100 watts x 2:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=252-125
*New vehicle and system coming soon.*
http://www.parts-exp...tnumber=245-500
http://www.parts-exp...tnumber=252-125
two of those links are both for the crown bro
PSN: Rcp_soundz
Fixed, thanks man
Good amp choices. But I'm in the same dilemma as the OP (not to thread jack) but what would be the best receiver for the money? I am not sure what to do with mids/highs but I will be running the crown amp you listed for my subwoofers. Thanks in advance for the help.
Audio Build
Ride: 2002 Chevy Blazer 4 door
Head Unit: Pioneer deh-80prs
Subs: 4 DC Level 3 15's in a 4th order wall designed by Trent Choate and Jeff Smith
Subs Amp: AQ 3500.1 at wired at .5 (soon to be 2)
Mids/Highs Amp: Skar 85.4
Mids/Highs: Skar components
Electrical: Mechman 270 amp alt, 2 runs of Knu 0 gauge, XS Power d3400, 2 Deka Group 9a31
Build log : http://www.stevemeadedesigns.com/board/topic/167658-indianabasshead-blazer-dc-audio-4th-order-wall-build/
Perfomance Build
2003 Nissan 350z
Greddy Twin Turbo, 3" Test pipes with Borla high-flow cats, Crawford Performance Plenum, Greddy E-manage Ultimate ECU
Exedy Racing Clutch, Built Motor by Racing Innovations
Greddy Over-fender aero kit (1 of 20 ever made), 19" Racing Hart r5 pro wheels
466rwhp
Bike
2008 Midnight Blue Kawasaki ZX-14
Stretched 8" and lowered, Brocks Sidewinder exhaust, Power Commander 5
Pioneer especially, and Denon are well revered in the Home Theater market. Sherwood (the stereo receiver I linked above) makes Receivers in 5.1 and 7.1 too. They're basically the Hifonics of the Home Receiver market. They'll make power, but not a lot of clean power.
  • 4 weeks later...
Two things: so you're running 8 mids per side right? What about tweeters? Any thought into this, how many what kind, matching sensitivity etc? What about xover points, testing different points and slope? Sounds like a can of worms really if you're just thinking mids.....
But for a short answer, you can find good used HOME receivers on ebay that would supply enough power for 16 drivers, which by the way can deliver quite a bit of spl, so you dont really need some crazy ampitheatre amp. Older NAD, Marantz, Mark Levinson, Carver (they have some great sounding M200T amps that will do I think 400w or 600w mono, I used two of them in the past and it was more than I needed).
For the sub section, yeah BASH is considered cheap cost, and really good sub sound. They also make 1000w amp!
But its all a lot of work for little return if you dont plan your system properly, it will sound like crap unless you do a good design. You can check out Parts Express.com and check out their projects, there are some line arrays already done/tested. Maybe they can help....
