Interchangeable Port Question
SlamminBeats
Quick question: So i want to make an interchangeable port. I'm going to keep the port length the same, so all i'm doing is adding a rectangle which will make my current port smaller, thus yielding a lower tuning. I've never made one of these before and wanted to know if this is ok? All the interchangeable i have seen always have that port length insert. I don't want that, is that ok?
Also, im just going to use T nuts and bolts to hold it in place. Is that the correct way to go about this?
Let me know if i'm correct!
Thanks
Check out Snowdrifter's build with his Subie. He just bolted pieces of wood to the inside of his port to make the port area smaller.
Here you go: http://www.stevemeadedesigns.com/board/topic/145655-subaru-forester-crescendo-crossfire-and-dc-power/page__st__40
2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant
- Fi and Crescendo - Stock Bose System
- http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota
136.4 Sealed @ 29hz
137.0 Drivers window open @ 26hz
I've tried it a few times and it just never works as good in practice as it does on paper. Sure you may be tuned lower, but the drastic loss in port area doesn't yield the gains you'd expect. If anything, I would make the port longer outside the box to keep the same volume and port area but lowering tuning.
-Drew
uhoh_45 said:
-Drew
almost like an external?
yeah- a normal inside port with an external extension to drop tuning I guess. That way the volume and port area remain constant.
-Drew
-Drew
how do you calculate that into torres? when i just add external length it barely drops tuning, id need like 30 inches external it seems like.
Sorry man I don't use Torres I don't know what to tell ya.
-Drew
  • Who's Online   0 Members, 0 Anonymous, 3081 Guests (See full list)
