So most amps are wired to the ACC on your key. My new amps for my new car will be wired to ACC to my key of course; but I also want a switch. So when the car is turned ON, if the switch is in the ON position (where it'll normally rest) the amps will turn on, like they should.
However, if I see a cop or if I want to test part of my system, etc. I want to be able to flip the switch and kill some of the amps.
My questions is ...
Say for example it's 1000 watts RMS.
So 1000 / 12 V is like 80 amps or so.
Where can I find a switch small enough but that is rated for like 80 or 100 amps? I don't want it to melt.
I've only seen these where I work (a solar company) in big DC disconnect form
Thanks guys
~Matthew
1998 Toyota Camry XLE V6 3L
(1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm
with Shock and Proximity
(1) 20% Tint All Around (Gately Audio)
(1) 250 Amperage HO Alternator
(1) Big 3 Done In 1/0
(2) Kinetik HC2400 Power Cell
(1) Alpine IVA-D106 Receiver
(1) Peripheral Video Bypass Device
(4) Alpine SPS-17C2 Speakers
(1) Alpine KCE-422i iPod Control Interface
(4) Sheets Dynamat Extreme; for speakers
(1) 10 Square Feet Hushmat (Trunk & Rear Deck)
(4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils
(1) Wall Built By David, Tuned to 32 Hz
(1) Rockford Fosgate T40001bd Amplifier
(1) Stinger 1/0 Wiring (2 runs of + 2 runs of -)
(1) Stinger Volt Meter
You do NOT wire a switch on the power wire....
A little switch on the remote wire (10-15 amp handling should be fine) is what you would do.
My questions is ...
Thanks guys
use the switch to power the remote turn on wire on/off. not the main amp battery wire. get atleast a 3amp rated 12 volt switch
http://www.stevemeadedesigns.com/board/ind...showtopic=29213 "sleeper build"
(1) DC AUDIO Level4XL 10
(2) PowermasterD2700 batteries
ALL FOR SALE
TEAM DC AUDIO
TEAM DIRTFLOORPOOR
Ah great! thanks so much guys that cleared it up alot for me .. I'm newb! hahahaa
Okay thank you
~Matthew
hha it's okay i apprecaite your help! i might PM you for stickers too heard you were great :)
okay its DC right not A/C
~Matthew
looks clean bro!
~Matthew
  • Who's Online   0 Members, 0 Anonymous, 4391 Guests (See full list)
