Joe X Posted November 30, 2012 Report Posted November 30, 2012 It would need to be 38.5" wide and it can be done, don't think you need it though, Doesn't seem like will be unloading issues or that the side placement will choke the port like. But yes it can be reworked to a center slot.
whotry Posted November 30, 2012 Author Report Posted November 30, 2012 Hey joe if you don't mind can you sketch one up with a port in the middle. Thanks in advance
Joe X Posted December 1, 2012 Report Posted December 1, 2012 Sure: Enclosure Specifications: Fb = 33 Hz Vb = 5 ft^3 External Height = 15 in External Width = 39.5 in External Depth = 25 in Port Width = 5 1/2 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 39 1/2 x 15 Left & Right Sides = 22 3/4 x 13 1/2 Top & Bottom = 39 1/2 x 22 3/4 Shared Port Internal Assembly Parts: 2 x Front to Back = 20 x 13 1/2 2 x Extension = 1 1/8 x 13 1/2 Assembly guide (generic dimensions):
whotry Posted December 1, 2012 Author Report Posted December 1, 2012 Hey joe if you dont mind can you post the screenshot of torres for me i want to see how everythings is plugged in. Thanks in advance.
Truconcept Posted December 1, 2012 Report Posted December 1, 2012 Joe X: whats the down side 2 not making the port L shaped and just straight 1 piece? i build noob boxes 4 my noob friends in school sometimes and never L the port id love any advice no drama on your design **actin bad like a kid at six flags**
Joe X Posted December 1, 2012 Report Posted December 1, 2012 The suggestion is Torres verifiable, use port length 27.5", 0.086 cubic feet per sub of driver displacement, 2 common walls, the rest of the info is given in the cutsheet. Use the older Torres though, the new one has significant flaws for now.
whotry Posted December 1, 2012 Author Report Posted December 1, 2012 thanks joe x, dont know what i would do without you.
Joe X Posted December 1, 2012 Report Posted December 1, 2012 Joe X: whats the down side 2 not making the port L shaped and just straight 1 piece? i build noob boxes 4 my noob friends in school sometimes and never L the port id love any advice no drama on your design Many DD reference designs port to the side and keep the sub away from the internal end.. These boxes could be done turning the port.
whotry Posted December 1, 2012 Author Report Posted December 1, 2012 Sure: Enclosure Specifications: Fb = 33 Hz Vb = 5 ft^3 External Height = 15 in External Width = 39.5 in External Depth = 25 in Port Width = 5 1/2 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 39 1/2 x 15 Left & Right Sides = 22 3/4 x 13 1/2 Top & Bottom = 39 1/2 x 22 3/4 Shared Port Internal Assembly Parts: 2 x Front to Back = 20 x 13 1/2 2 x Extension = 1 1/8 x 13 1/2 Assembly guide (generic dimensions): Hey joe is the last extension dimension correct? Isnt 1 1/8 1.125. If that is right just let me know I just want to be sure before i start cutting.
Joe X Posted December 1, 2012 Report Posted December 1, 2012 Yes, 1 1/8", the sketch is of generic dimensions so it shows them longer than they actually are for your box.
