whotry Posted November 28, 2012 Report Posted November 28, 2012 Hello everyone, I just picked up 2 12 L7s 2 ohm dvc and Im in help of building my first box. I have a 2nd generation Lexus GS300. Im a noob to this but would love to build my own box. My trunk dimensions are Max Height = 15 Max Width=65.5 Max Depth = 10 I was planning to tune it around 33 Hz with one or two ports, if someone can help me out with calculating everything I would greatly appreciate it.
Truconcept Posted November 28, 2012 Report Posted November 28, 2012 try using torres box calculator **actin bad like a kid at six flags**
Joe X Posted November 28, 2012 Report Posted November 28, 2012 Hello everyone, I just picked up 2 12 L7s 2 ohm dvc and Im in help of building my first box. I have a 2nd generation Lexus GS300. Im a noob to this but would love to build my own box. My trunk dimensions are Max Height = 15 Max Width=65.5 Max Depth = 10 I was planning to tune it around 33 Hz with one or two ports, if someone can help me out with calculating everything I would greatly appreciate it. You would need to have like 15" deep, also even if you have that width I am not sure you would be able to fit it in it's way in.
whotry Posted November 28, 2012 Author Report Posted November 28, 2012 I have enough more depth to add but idk if it will work my trunk is weird it has a small opening in the back then opens to a larger opening would I be able to build a box to fit the small opening and expand it ? Here's a picture of the trunk.
whotry Posted November 28, 2012 Author Report Posted November 28, 2012 http://i8.photobucket.com/albums/a11/mobster909/Installs%20-%20cars%20-%20audio/Lexus%20GS300/DSC03642.jpg
Guest Posted November 28, 2012 Report Posted November 28, 2012 you'd probably want like 4-5 cubes after displacements.
Joe X Posted November 28, 2012 Report Posted November 28, 2012 The method I usually suggest is to build a cardboard dummy box the size you think it can still fit. but anyways, the box can be made not as wide and a little deeper or even taller depending on what you have.
whotry Posted November 28, 2012 Author Report Posted November 28, 2012 Can someone use Torres to spec a box to 5 cubes I work graveyard shift so I have no computer access
john253a Posted November 29, 2012 Report Posted November 29, 2012 i ran a single L7 in 7net 90sqin of port on 1k for a while and loved it dont tune them low is all i can say and with the measurements you've given don't even have enough room for ONE L7 let alown 2 just for ONE L7 youll need a box of 65x16x15 to get 6net with 87sq" port 35-37hz if you can get 65x16x27" deep you can run 2 @35-37hz with 170-180sq" of port and have 10net but idd per 30"deep to give you 12net
Joe X Posted November 29, 2012 Report Posted November 29, 2012 Can someone use Torres to spec a box to 5 cubes I work graveyard shift so I have no computer access I can do it just tell me what dimensions you can fit in the way into your trunk. Im sure it will be less than 65"
