Nate197 Posted November 30, 2012 Report Share Posted November 30, 2012 Im about to start fiberglassing and was wondering what type of staple guns you guys use and what size staples? I have some 1/2 mdf I was going to use for my component speaker fiberglass project. Thanks Link to comment Share on other sites More sharing options...
NYC54 Posted December 1, 2012 Report Share Posted December 1, 2012 Upholstery staple gun is what you need , I have a porter cable that works great , or you can buy a cheap one on eBay they have a flat nose at the end , buy a few size staples because you never know what size you might need Link to comment Share on other sites More sharing options...
Smoove Posted December 23, 2012 Report Share Posted December 23, 2012 To us the 5/32 staples you need a special stapler or are most of you guys using the staplers that go down to 1/4? 22g or 18g 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/ Link to comment Share on other sites More sharing options...
dereileak Posted December 23, 2012 Report Share Posted December 23, 2012 I use hot glue, makes it so much easier, you can get everything to stick exactly where you want without the damn staples not going through and stuff on these thick plastics 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments) Link to comment Share on other sites More sharing options...
Smoove Posted December 23, 2012 Report Share Posted December 23, 2012 does the cloth/fleece stay tight using the hot glue? getting as much info as I can because I will be doing my doors soon 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/ Link to comment Share on other sites More sharing options...
dereileak Posted December 23, 2012 Report Share Posted December 23, 2012 does the cloth/fleece stay tight using the hot glue? getting as much info as I can because I will be doing my doors soon it did when I did it, you just put hot glue on the plastic, like 4-6 inches at a time, pull it tight over it, and hold it till it dries in like 20 seconds or so, and it holds really nice, you go through a lot of hot glue, but I had mini sticks, staples are probably the best, but hot glue works great in my opinion, the more you work with it and figure out where to glue and stuff the better you get at it if you work with fleece to stretch over it, then it holds awesome, I ripped up some stuff that I didn't put in the right spot and it was on there hella tight, hard to rip off, glue works good for when you design the braces with wood too, just glue the dowels and the speaker rings where you want, then fleece overMy doors I did More hot glue for dowels Is this your first doors ever? 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments) Link to comment Share on other sites More sharing options...
Smoove Posted December 23, 2012 Report Share Posted December 23, 2012 Thanks for the info. 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/ Link to comment Share on other sites More sharing options...
dereileak Posted December 23, 2012 Report Share Posted December 23, 2012 Thanks for the info. yea, just be careful if you are fleecing over the whole door, it can get to thick in some parts and make it so the door doesnt fit, I put like 10-15 hours just sanding and fitting the doors so they would close cause of this :/, better to only fiberglass over the parts that are custom that you want 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments) Link to comment Share on other sites More sharing options...
Smoove Posted December 23, 2012 Report Share Posted December 23, 2012 Yes this will be the first time doing doors. Only fiberglass I have ever done was patching some motorcycle fairings. And since it was a track bike I didnt care how shitty it looked. 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/ Link to comment Share on other sites More sharing options...
dereileak Posted December 23, 2012 Report Share Posted December 23, 2012 Yes this will be the first time doing doors. Only fiberglass I have ever done was patching some motorcycle fairings. And since it was a track bike I didnt care how shitty it looked. Well Good luck, ask questions if you need, I have only done 1 set of doors, you learn so much on your first time, and every time after too, here are the 2 best guides I have found on the net for fiberglassing, they helped me a ton http://www.j-body.or...i=74970&t=74970 http://www.yourcusto...oor-panels.html they will teach you a lot of tricks and things, they took me a long time to find on the internet searching through all tons of crap Fleece works good if your doing boxes, but if I did doors again I would use a thinner material that stretches easy, cause the fleece gets thick and sucks a lot of resin, and if you had thinner material you could get the details to work out much easier 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments) Link to comment Share on other sites More sharing options...
