clipping indicator on AQ 1200?
pk222
I just installed my Aq amp. So far seams like a great amp but the clipping indicator on the bass knob starts coming on really early.
I swapped this out for my old performance teknique 800 rms amp. Haven't changed anything other than the amp and I've run this setup for months. I'm running 2 older alpine type r's at 1 ohm. Any ideas what I can check? And for this being at least 400 watts more than my last amp it sounds about the same. I've heard nothing but good reviews on aq so i'm thinking I missed something. Help me out guys!
400 watts is barely an audible difference my man. And I have my amp tuned with the DD-1 and it says it begins to clip way before I reach full tilt.
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
My 2200d clip light would do the light clipping at the point at which the dd1 found dis.
Then less than two weeks later the knob died lol
No real point to use them imo
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
^^ Cant wait to swalllow Ghost's babies
Ok. Just wanted to make sure I didn't have a problem. First day messing with the amp and didn't want to fry it if there was an issue
Any chance that could be caused by a burnt coil or anything else I can test? my subs are kinda old and abused. just feeling like that light is coming on way to early
i got the same amp. my gains are set with the dd-1 some songs the light will flicker alot, others it will be solid. you cant trust those clipping knobs.
its good if you dont have your amp tuned with the dd-1 or o-scope. just dont let it be solid red. i dont use mine anymore..
I just tuned by ear for now with the bass boost at 0. I'm going to try to get it done with an o scope soon
If the clipping indicator just flickers as the frequencies in the music change you are not really into clipping. If the light glows solid back it off until it just flickers with the frequencies changes in the music.
dj
  • Who's Online   0 Members, 0 Anonymous, 615 Guests (See full list)
