afrakes Posted December 8, 2012 Author Report Posted December 8, 2012 I've had bad luck with an explorer that will keep me away from ford, forever. Yeah my old man had a mountaineer a few years back, bought it at 60k miles, and it shat on him at 80k, so I'm pretty skeptical when it comes to fords, at least older ones... Vehicle: 2014 GMC Sierra 2500HD WT Head Unit: Pioneer DEH- Mids/Highs: Focal Integration ISC 165’s (front) Subs/Amps: TBD
boom50cal Posted December 8, 2012 Report Posted December 8, 2012 Iirc, the trannies in the V8 explorers were actually the trannies for V6 F150's, but don't quote me on that. I know for sure the 03ish-06 6 speed auto's came out of Lincoln LS's. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
STEvil Posted December 8, 2012 Report Posted December 8, 2012 Yeah, the transmissions are junk.. and the explorer lost value just driving it off the lot. It earned the name "exploder" for a reason.. Chevy/GM 5.3's and 5.7's will last forever. They're not the greatest fuel economy wise with an automatic behind them, but the 4L60E and 4L80E last pretty good as long as you dont intentionally try to kill them. Watch for play in the transfer case (chain driven) and front diff, thats the weakest spot after about 150-200k miles if the 4x4 was used a lot. If you take care of the engine you can expect them to go forever lol. 4.6 is the best C/GM v-6 but its horrible fuel economy wise if you dont keep the electronics all working (o2 sensors, rotor/cap, plugs, wires) and clean/delete the cat.. Jeep 4.0 has similar issues fuel economy wise and has a tendency to leak but other than that the platform is solid as long as you dont beat it like a trail rig in stock form and expect it to stay perfect. Toyota motors are generally good, just gotta watch timing chain issues on some of them (the 4-bangers mostly) and overheating/pinging issues on a couple of the v-6's. Manual transmission will provide the best fuel economy but you need to be sure you're picking one that wont need servicing soon.. Good luck, 25mpg is about tops for 4x4's under 5.0L usually... MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
wcefai Posted December 8, 2012 Report Posted December 8, 2012 My family just bought an 04 4Runner. 4.0L V6, averages about 19mpg and is perfect for us (needed something to pull out ski boat). I've heard 4Runners are tanks and am already loving ours
glockman513 Posted December 8, 2012 Report Posted December 8, 2012 I've had bad luck with an explorer that will keep me away from ford, forever. Yeah my old man had a mountaineer a few years back, bought it at 60k miles, and it shat on him at 80k, so I'm pretty skeptical when it comes to fords, at least older ones... Bought mine with 47k on it, replaced the transmission at 52k. If you're feeling DOWN & OUT, it's time to get UP & IN
From_the_Valley Posted December 15, 2012 Report Posted December 15, 2012 Any GM with the 5.3L will last when put to the test. We have a few 05's at work with hard miles on them and they still won't quit. Good luck
