Crunch PZA2000.1?
CDetty
Well I saw this amp on Sonicelectronix for $99 and decided to take a look.
http://www.sonicelectronix.com/item_33124_Crunch-PZA2000.1.html
It's got 4 30 amp fuses which means 1728 watts? Correct me if I'm wrong of course. 1700 watts would work well for the system rebuild I'm finally getting around to.
1999 Honda Civic- RIP
2003 Acura RSX Type-S
You might see 1200 watts at most outta that amp. I'd stay away from it and get a quality 2k amp.
2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant
- Fi and Crescendo - Stock Bose System
- http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota
136.4 Sealed @ 29hz
137.0 Drivers window open @ 26hz
It's a 1000W RMS amp.
You wouldn't hear a difference between 1000W and 1700W, but i'd suggest you'd go with a better amp.(buy atleast hifonics BRZ)
I would call Maxxsonics first about the true output. I know when I talked to one of the tech's he told me the lower line stuff is all max rating not rms. For instance he told me that the Hifonics zrx500.2 only puts out around 230 rms brigded. Sonic has this listed as 500 rms. As f]or the Crunch using 120 amps worth of fuses so does the new Hifonics Gladiator which is 1000 rms.
2004 Dodge Ram
Head unit- Alpine iDA-x305s
Sound processor- Clarion eqs746
Mids/Highs amp- Alpine MRV-F345
Sub Amp- Alpine MRD-M1005
Dash Speakers- (3) Dayton Audio rs75
Front Door- Skar SPX65c
Rear fill- Skar SPX tweters and Dayton ND140 midbass
Sub- Fi Audio SSD 15 high QTS
SHCA power/ground cables and Stinger interconnect
XS power D6500 under the hood and D680 in the amp rack
Big 3+ with SHCA
http://www.stevemeadedesigns.com/board/topic/161174-dodge-ram-quad-cab-fi-ssd15-skar-audio-alpine-shca/?p=2326251
LOL is that with gain and bass boost turned up, and clipped to hell?
That amp can probably do 800w rms on a good day.
The fact that it's on sonic (legit site, my personal fav) and yet:
RMS Power @ 4 ohms [color=#b22222][b]Not specified by manufacturer[/b][/color]
RMS Power @ 2 ohms [color=#daa520][b]Not specified by manufacturer[/b][/color]
RMS Power @ 1 ohm [color=#ff0000][b]Not specified by manufacturer[/b][/color]
Bridged RMS Power [color=#ffa500][b]Not specified by manufacturer[/b][/color]
also:
Its a problem amp, id stay away, when i turn it off i hear a sqeeling sound from it,
after like a month i had it at 2 ohm and it caught on fire ,but it still worked lol.
And sometimes this amp would just go into protect mode the sec i turned it on,.
.....pza models are junk.
If you want something cheap, poorly designed; swap meet style amp then this is for you
ROFL
Are you talking actual RMS from any amp? I'm pretty sure I would notice a difference from a 1000w rms and 1700w rms amp. Depending on the drivers the amp is powering of course.
Seconded on the hifonics. They are made by the same company. I still wouldn't personally run hifonics unless the price was really good. They aren't bad, but aren't the best either. With a warranty from frys, they are actually a pretty good choice. Used, not so much.
Also, my rockford P500-2 amp which does 500w rms bridged had 4awg inputs. was not 2 ohm bridged stable. This amp is rated for 2000w max, 1 ohm stable, and has 4awg inputs. HMMMMMMMMMMMMM
2010 HHR LT - DNX 6160 - sony xec-700 - sony xm-4040 for door mids - XM-6020 for tweets in a-pillar - saz1500d v1 - VVME RD-12 1.75 f^3 32hz
guru and president of the "cheap asses trying to beat up the block with bargain bin woofers" club
Ive installed one that one of my friends dad gave him.
It all depends what subs you are running. This can push a couple of 400rms subs no problem and have them hitting but by no means use this for powerful subs. I dont like the crossovers too much but it does put out a good 700-900rms.
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
  • Who's Online   0 Members, 0 Anonymous, 1335 Guests (See full list)
