Jonathan Frykberg Posted December 7, 2012 Report Share Posted December 7, 2012 Hello, I know these questions get asked lots but i am looking for some help with and enclosure design. I would like to put 2 sa8 v2's where the stock sub is in my 2000 yukon xl. I would like to keep the box behind the panel with just the subs themselves comming through the panel.I would like to be able to use the lift out storage tray/jack cover spot for the port. Also what amp would you suggest for these subs? Thanks everyone in advance Link to comment Share on other sites More sharing options...
Joe X Posted December 7, 2012 Report Share Posted December 7, 2012 A good quality1500W RMS amplifier should cover your needs with a couple of those subs, in regards to the box, you need to post the maximum dimensions you have for it. Link to comment Share on other sites More sharing options...
Watch the bass Posted December 7, 2012 Report Share Posted December 7, 2012 What´s your budget Jonathan? It´s for his output a hughe amp. It´s a class G amp that means he combines the sound of class AB with the efficiency of class D. The reference series is known as awsome, you can get the amp for a sellout price. http://www.ebay.com/itm/NEW-SOUNDSTREAM-REFERENCE-REF1-1000-1000-WATT-RMS-MONO-SUBWOOFER-AMPLIFIER-/150942024117?pt=Car_Amplifiers&hash=item2324d881b5&vxp=mtr "in the abundance of water, the fool is thirsty" Bob Marley Link to comment Share on other sites More sharing options...
john253a Posted December 7, 2012 Report Share Posted December 7, 2012 i dont think there going to fit in the sid panel as u want, they are a monster of a sub and hence have some depth and weight to them maybe look at the E series for that but youll be better off looking at Fi audio IB range as there more suited for style install, if on the other hand you want to build a nice ported or T-line for them and take un some of the trunk then there a very nice sounding sub ported 1-1500rms @ final ohm load, 1.2 net 28-35hz T-line 3-400rms @ final ohm load, 80sq" of port 95" long (35hz) im running 2 in a T-line in my workshop on 100rms and there as loud as my 2x v1.5 on 400rms in a ported box so i think you have some more reading and research do to but always happy to help if needed Link to comment Share on other sites More sharing options...
Jonathan Frykberg Posted December 8, 2012 Author Report Share Posted December 8, 2012 thanks for the replies. i will post my maximum dimensions soon as i get home as i am cuyrrently at work and i work out in the bush for 15 days at a time. I already have the subs so yes i know they are deep, and yes i am aware that other subs may fit " nicer " but i got these for a purpose. I dont mind it protruding a bit from the panel but the less the better. Watch budget isnt really all that big of a deal but definately will not go with another soundstream product as i have recently had nothing but issues with them in my last truck. but thank you for the suggestion. Link to comment Share on other sites More sharing options...
