04 Dodge ram 2 HDC318's build (AQ Build) **New box build**
So I've started my build. here's what I got- Pioneer P8400- (2) AQTS6.5- (2) HDC318- AQ 2200D- AQ 120.4- (3) Deka Intimidator 34M (Plus front batt)- Knu wire, RCA, etc.I'm going to try something different with the box. I was going to do the typical subs firing forward, port up, but thought I might try something else.Instead, I'll be doing subs/port all firing up towards the roof, with the subs inverted (I can mount them normal as well).I'll be building a different box after I get done with this one with subs forward, port up, see which I like better, than rebuild it double baffled with baltic bitch.So here is how the layout will be. NOTE: The 2nd 2200D was Photoshopped in there. I will eventually get a second one.SUBsetup2.jpgphoto10.jpgThe box is angled with the front seatsphoto11-1.jpgAfter using a circle jig to cut my sub holes, I find out they're too small. AQ's site says the cutout is 16.5" when it's actually 16.750" :angry22:So I screwed a 2x4 in place, than I screwed the old cutout to the 2x4 to get my pivot hole in the same place and it worked.photo12.jpgphoto13.jpg1" Dowels for bracingphoto14.jpgphoto16.jpg^As you can see, I missed a total of five screws out of about 200 :sigh:photo17.jpgphoto18.jpgI still have a lot more to do...I slapped this together for the batts. They will go in the bed. I think I'm going to rhino line it...photo22.jpgMy brother stopped by, drank all my kool-aid, took some pictures, and didn't even help. lolphoto26.jpg
2 HDC3 18's
AQ2200D
Cool build let's see more
2008 Black Chevy Tahoe -Murderedout/ 2/4 Belltech drop/26" U2-55's/ HID's in fogs and headlights/G5 tails1 - BC35001 - C1100.42 - SA ZV3 18's6 - 8" SA Neo Pro's2 - FT1-SE Tweets
Thanks.
Got some more work done today...
Port. This port will be tuned at about 32-33hz
I filled in and sanded the corners with bondo
Filled most of the hols in the box. I still have more to do.
T-Nuts for the port. I love these things
Laid some resin to seal everything up.
And my helper for today
2 HDC3 18's
AQ2200D
Well, not to take away anything from yer arm work , I rather focus on yer bass build LOL
Definitly looking good.. I'm in :popcorn:
Don't like sharing your knowledge?
Welll.. Don't come here and grab others then! - GTFO.
LOL
Well I didn't do anything for the past three days. It was raining, super cold, and I freaked out (That's not suppose to happen in AZ) LOL...
Anyways, it was nice out today, and I got some stuff done.
Battery bus bars
I sprayed rubberized bedliner and mounted the battery box
I installed a tonneau cover on the truck
Almost finished laying all the resin. I only have one side left
I did some more sanding on the box. I also soldiered and ran some ground wire. They're grounded to the frame.
2 HDC3 18's
AQ2200D
Def. post up some vids once your done bro...coming along good though! Nice work!
if you put a DD-1 in your amp terminal and it immediately went up in smoke, i would be concerned.
If you shoved your dick in the terminal and it didn't blow up but a month later it blew up, i STILL WOULDN'T be able to blame your dick.
It just does not make sense at all.
