so the other day i noticed my rubber floor mat was filled with water on my passenger side, well today i was feeling around and under that its a bit damp and in the back seat its a lot more damp. my question is could it be caused by the ac line because it has a huge hole in it from the cold air intake rubbing?
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
2 15s 4inch coil psi recones temp til my subs are reconed
Focal P165-v15
Audison voce quattro
fully active
Only gonna get louder
146.1 at 38hz
138.x at 24hz
Build log
http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/
kind of car? and does it have a sunroof?
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
ummmm where do you park your car? is there water surrounding by where you live?
2010 Mazda 3
*Rebuild Time*
Subs - (2) AA Mayhems 12's
Sub amp - (1) Populus Audio TPA 6500
Headunit - Pioneer App Radio 2
Batteries - XS Power (1) D3100 up front | 6 XP950 rear
Wire - Sky High 1/0 Gauge wires and RCA's and steve's VM1
Alternator - Singer 260 Externally Regulated
Front Stage: (2) PRV Audio 10W650A (4) PRV Audio 8MR500-PhP-4 (4) DS Bullet Tweets | (2) 6.5 Components (Rear doors)
Mids & high Amp : (2) Populus Audio 100.4
Processor: Rockford 3sixty.3
The Build Log : http://www.stevemeadedesigns.com/board/topic/175922-2010-mazda-3-2-aa-mayhems-12-pg14-new-video/page-11
wet coast of b.c but in my driveway
2000 acura integra and yeah has a sunroof but i cant find any water marks around doors or windows just damp carpet :(
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
that weird bro
2010 Mazda 3
*Rebuild Time*
sunroofs have drain lines that go down your A-pillars they aren't 100% sealed. if these drain lines get clogged, the water backs up in the sunroof. It will take the path of least resistance sometimes running down right next to the drain line, and out onto the carpet. To test for this, open your sunroof and pour some water in the metal lip, you can see the drain holes usually in both front corners. If the water stays there, or drains very slow, you need to clear out the line. Usually easily done with some compressed air and a spray nozzle tip.
so it wouldnt be caused by the hole in the ac line?
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
I couldn't tell you 100% positive, but it would depend on where the hole was...another thought is whether or not you have rust on the car.
alright im going to check all the drainage lines tommorow or when ever the weather is a bit better :)
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
