4th order in camaro wat do u think
kingofslowbass
Instead of drawings, give us some hard numbers and measurements to work with :)
Like internal volumes, port area, tuning, etc
ill try and get the measurements up after work tomorrow ill do a video on youtube check it out kingofslowbass also subscribe
94 z28 m6 cyber gray metallic custom pant with white strip black ss wheels and spoiler 249whp 295trq. in progress is a 4th order with 2 Obsidian 15s for SBN so subscribe to my youtube kingofslowbass to watch it all go together.
its a quick drawing so i can show people what i am doing and get there opinion
Get it right, perspective and proportion are coherent, your drawing is good!
"in the abundance of water, the fool is thirsty" Bob Marley
The picture and the drawing are not of the same thing. I'm sure enough space is available since the area of the rear seat is being utilized. It's a lot of room to do a 4th for 15s though, as previously stated. Tuning to mid 40s is typically the goal for a 4th
I can see a 4th order design in this drawing and in this way i stated!
The cargo area under the hatch looks to be unoccupied? The actual pic shows sometning different than your drawing. Btw, you didn't answer the question, but it appears its a 4th generation F-body.
how is the pic
diff from the drawing
Really dude? Because the baffle-like cutouts are resting on the shelf that WOULD be right behind where the seats used to be. I'd say that makes it much different than your drawing. Do you know how much airspace you have to work with? What kind if dimensions are you wanting to dedicate to this box? Also, you know how tuning a 4th order works right? Like proper tuning frequency and such?
how is the pic
i think you need tom look at the drawing again!
I see the weird wedge on the back area where the subs are just inverted and not sitting in the sealed space. I'm retarded and apologize, now I can see it. So that wedge must have around 4-6cubes? Same with the ported area, it's around 8-12 cubes?
They will do well in a 4th, might have loading issues with the port though, try to keep them from firing directly out the port.. give them 3 cu ft sealed and and up to around 8-9 ported, tune around 43 hz or so and you'll have your lows.
i want 23,26-38hz and thanks for your input ineed as much help as possible with tuning,port size and i just want this for SBN
  • Who's Online   0 Members, 0 Anonymous, 1103 Guests (See full list)
