DC Sound Lab
Hello !
I'm about to plan a box for 2 12" level 4 with 2 DC 2.0K's
As there is more power than recommended, I thought about shrinking the enclosure's volume.
Would 1.25-1.3 each be o.k or should I shrink it more to about 1.1-1.2 or so ?
Thanks !
Just to drive you guys to help a bit more, here's the install of the current setup:
2007 Golf GTI Stage 2
Before:
Making some plans:
Proud with his brands:
The 2.0K:
Celestra FA 475X:
4x90 @ 4 ohms
Behinf the scene:
0 AWG CCA- another one would be added, maybe will be replaced with OFC's.
Hertz High Energy XL- Great component set!
Final result- clean and tidy !
12" Level 4, the port is at the side of the box.
so....
Does someone has a good recommendation of volume? maybe CJ of Jeff ?
I'm tuned in :) just put a dc lvl 4 m2 10 on a ap1500d in my gti mk6. Get's nasty great driver!
-BriAn
12" RD Audio Alpha v2 with PAP softparts. 3"ww 8layer al vc
Recoil RED 1000.1
Audiopipe 0 gauge wiring kit
Kinetik hc600
5 Farad Capacitor
2.26cuft slot ported box tuned to 30hz
(bbp6 says its 37hz 12volt says 30hz)
If it helps, just installed 2 Lvl 4 12's in my jeep in a box with 3 net cubes, 6 inch aero port at 36hz, sounds great. Although, I would go smaller since your going to be pushing a good bit more power considering mine are on a Memphis Mojo 2500. Can't imagine how loud it will be once I turn the amp up, just waiting until I install my mechman 320a to avoid voltage drops.
Edited by Gladski462
08' Grand Cherokee
(2) DC Lvl 4 12's
  • Who's Online   0 Members, 0 Anonymous, 5415 Guests (See full list)
