Rockford96 Posted December 20, 2012 Report Posted December 20, 2012 After xmas i plan on purchasing a audiopipe apsm1500 and running ut at 2 ohms like 900 clean watts can i get away with this on stock electeic? I think my truck has a 110 amp alt and just normal truck battery in it ill run it with 0 gauge cca only like 12ft long what do u guys think should i add a hc800 in the back? My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
Watch the bass Posted December 20, 2012 Report Posted December 20, 2012 I would try it frist without the hc 800, install a voltmeter them cheap, if you got dimming or want a little bit more stability in your system, here a link to a nice offer on batt´s http://www.stevemeadedesigns.com/board/topic/144556-dont-seem-like-a-bad-deal/#entry2272320. "in the abundance of water, the fool is thirsty" Bob Marley
Maebros Posted December 20, 2012 Report Posted December 20, 2012 it wont hurt. HU: Pioneer AVH x5800BHS SP Amp: AQ 120.4 Front SP: Hertz Hsk 165 Rear SP: DD cxs 6.5 SW Amp: Crescendo BC2000d SW 2 DC level 3 12" Electrical: Stock alt for now XS D2400 XS D3400 Knukonceptz Kolossus Second skin damplifier On 8/8/2012 at 4:50 PM, Brandon15zzz said: I heard he actually graduated college with a 4.0 gpa. Seems pretty gangster. On 8/29/2012 at 12:25 AM, ILoveBass21 said: he could blow a sub powering it with a potato.
Rockford96 Posted December 20, 2012 Author Report Posted December 20, 2012 I would try it frist without the hc 800, install a voltmeter them cheap, if you got dimming or want a little bit more stability in your system, here a link to a nice offer on batt´s http://www.stevemeadedesigns.com/board/topic/144556-dont-seem-like-a-bad-deal/#entry2272320. thats what i was thinking see how i stand without it and if i need it do it thanks for the link and my truck euns prwtty high volts idle almost 15 thats nice thanks again My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
ds1919 Posted December 21, 2012 Report Posted December 21, 2012 well your alt can take the demand, but you gotta think of the big 3. If any of those wires are not capable of transfering about 90-100 amps, then you can damage your electrical system. I would deffly upgrade that part, you can even leave your stock wiring in place, just add a second run of like 6 or 8 ga wire. Thats the cheap way of course. never hurts to be safe. I fried my car once a long time ago with a 600w Orion 2150gx (600w @2ohms, 80amps). No fun!
Kyblack76 Posted December 21, 2012 Report Posted December 21, 2012 A- that AP amp isnt a upgrade. B- .... that AP amp needs to be re thought.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Rockford96 Posted December 21, 2012 Author Report Posted December 21, 2012 A- that AP amp isnt a upgrade. B- .... that AP amp needs to be re thought.... what do u suggest on a budget then? My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
Rockford96 Posted December 21, 2012 Author Report Posted December 21, 2012 well your alt can take the demand, but you gotta think of the big 3. If any of those wires are not capable of transfering about 90-100 amps, then you can damage your electrical system. I would deffly upgrade that part, you can even leave your stock wiring in place, just add a second run of like 6 or 8 ga wire. Thats the cheap way of course. never hurts to be safe. I fried my car once a long time ago with a 600w Orion 2150gx (600w @2ohms, 80amps). No fun! ya i plan on doing it in knu cca hopefully My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
Kyblack76 Posted December 21, 2012 Report Posted December 21, 2012 Look in the used, FS section here.... really bro... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Rockford96 Posted December 21, 2012 Author Report Posted December 21, 2012 Look in the used, FS section here.... really bro... ok thanks My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
