momofx76 Posted December 21, 2012 Report Share Posted December 21, 2012 I got a box that was originally made for some Hifonics 15's - do you guys think this box is good enough for two AB XFL1544's? Here are the dimensions (note that the box has an angled back) : Width : 38" Height : 20" Bottom Depth : 26" Top Depth : 18" Port size (there are two at the bottom of the box) : Width - 14.5" , Height - 3.5" , Length - 21.5" Box is made with .75" MDF. What do you guys think? Link to comment Share on other sites More sharing options...
momofx76 Posted December 23, 2012 Author Report Share Posted December 23, 2012 Anyone good with the enclosure building software, etc. care to chime in on this box? Thanks. Link to comment Share on other sites More sharing options...
sbg Posted December 23, 2012 Report Share Posted December 23, 2012 Idk about your box but I'm going to be doing a build next month with 2 of the xfls 15s and a bb2400 in my explorer, love them subs! Seen the same setup and as what I'm talking about do 151db on tl sealed on dash on music! 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca Link to comment Share on other sites More sharing options...
Joe X Posted December 23, 2012 Report Share Posted December 23, 2012 I got a box that was originally made for some Hifonics 15's - do you guys think this box is good enough for two AB XFL1544's? Here are the dimensions (note that the box has an angled back) : Width : 38" Height : 20" Bottom Depth : 26" Top Depth : 18" Port size (there are two at the bottom of the box) : Width - 14.5" , Height - 3.5" , Length - 21.5" Box is made with .75" MDF. What do you guys think? 5.9 cubes @ 38Hz 101 square inches of port, guess not that bad if the box is solidly built. Don't know in which vehicle you intend to use it but it will probably be rather lacking on deep bass, best thing you can do is test it. Link to comment Share on other sites More sharing options...
momofx76 Posted December 23, 2012 Author Report Share Posted December 23, 2012 Thanks - I tried it out and while it did hit the very low notes, it got very loud at around 50 Hz or so. I am wondering if I should put some polyfil on all the walls inside it? BTW the box is coated with resin on the inside. Link to comment Share on other sites More sharing options...
Joe X Posted December 23, 2012 Report Share Posted December 23, 2012 In vehicles with high cabin gain you get the low notes from that, if the peaking at 50Hz bothers you maybe damping as you say can help some if you don't want to rebuild. Link to comment Share on other sites More sharing options...
momofx76 Posted December 23, 2012 Author Report Share Posted December 23, 2012 Ok thanks - I will try the polyfil and see if it does any good. Link to comment Share on other sites More sharing options...
