Termlab vs audiocontrol
so whats the big difference i see the meters hitting the same i know you can edit both of them i dont know by how far on TL but AC you can edit +-3 db
This question should really be in the "TOOLS and TESTING Devices" Page
(Old Car) 1995 Volkswagon Golf MK3 2.0L:
Fi SP4 18 On A DC Audio 3.5K In A PWK Box
Hertz DSK 6" Speakers, Clarion HU
3x Fullriver 120aH AGM's, 225A Alt
2012 Subaru BRZ:
Audison Prima APK 163
Bit One, Rockford Amps, Audison Sub
vs thread?
not a vs i wanna know the difference this proves there is none since everyone say ac is way different
the termlab is a pressure sensor. the AC is a microphone. you can not edit the termlab without it showing up in allt he results you do. Ive seen the ac tweaked easily. It also does not hold its true zero very well. Once its been blasted with a loud run it tends to start being inaccurate where as the termlab retains its accuracies. NASA uses the termlab. That should tell you something about its consistency.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
now see when u said it holds a true zero that i completely understand thank you n8 please close thread
i didnt watch the video. but if you did 100 runs with the possibility of turning the exact same reading with the termlab it will be accurate 100 times. so if you haev a device that can do 125 dbs every time you push a button you'll get that 125. the AC will be 124.8 15.1 etc. Some are tighter than others to start but they require calibration frequently. For the cost there is no reason to not get a termlab. Its the official meter of almost all associations. You will have some folks say that between meters they are off .1 or so but those case are rare and its tough to say what causes them.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
kno i know what your saying but everyone just says nasa uses it nasa could have used it once and said it was garbage they use some much stuff there and change things so much its not funny
  • Who's Online   0 Members, 0 Anonymous, 1129 Guests (See full list)
