jimmy191990 Posted December 26, 2012 Report Posted December 26, 2012 I was going to go with 2 fi sp4 but I think one will be good enough for now but I have a few questions. Should I get dual 1 or dual 2 im wanting the most power but I dont want to mess the subs up. This is just a daily system but I still want to be hitting close to 145+ DB. Also im having a hard time finding a good fuse? Im going to run 1 BC3500. This will be a trunk build. What size wire should I use for the sub 10?
2000s-10 Posted December 26, 2012 Report Posted December 26, 2012 D2... and what fuse are you tlking about?? Your power wire fuse? Andyou should be good with 10 gauge for speaker wire..I always just use 8 gauge 1999 grand prix gt kenwood x994 head unit 1/0 big 3 all shok industry single run to the back New mid/highs coming not sure what Soundqubed q2200d at .5 (have) 2 soundqubed hdc3 12s (have) New box to be built.. sealed firing forward (yet to be designed) 200 amp alt not sure exact size or manufactor xs power batts
Smoove Posted December 26, 2012 Report Posted December 26, 2012 What load are you planning on running that amp at? 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
jimmy191990 Posted December 26, 2012 Author Report Posted December 26, 2012 Im going to run it at 1 ohm and im talking about the fuse from the battery to the amp witch one should i get
Daniel J Blitch Posted December 27, 2012 Report Posted December 27, 2012 Not to be rude, but it seems to me you need to read more on this forum and get accustomed to building a system with more then a couple thousand watts. I have been reading this forum for over a year and just now building the confidence with help from people on here and local pro audio shop guys to put together a moderate system. You are going to have to put a lot of thought in electrical so your car doesn't burst into flames while your showing off. Building an Empire.
jimmy191990 Posted December 27, 2012 Author Report Posted December 27, 2012 I have hooked up a lot of systems around 2500 watts and I know what im doing just want a little advice on a few things. I dont need help hooking anything up
420c Posted December 28, 2012 Report Posted December 28, 2012 300 amp fuse from batt to amp to stay on the safe side also do big three upgrade under the hood and 8 guage wire to the sub. set your gains with a dd-1 or an o-scope or youll need a recone kit in the future happy bassn
