Can a bad power wire cause bad voltage drops at the amp?
Can having a bad power wire cause really bad voltage drops at the amp?
I've been having really bad voltage drops, and I don't know why
My electrical is a 55-100 amp stock alt, Deka G34, Big 5 done(Yes Big 5), and I'm only running 900 rms at 2 ohms(amp is rated to take 60 amps, so it's actually overrated)
My power and ground wire is a Cadence 4 gauge I got from a kit long time ago when I was starting out car audio
Here's some pictures
Voltmeter setup
amp wiring
and my problem
http://youtu.be/zi2HqvwUTsI
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
mine goes to about 12.8 13 when under load i have 4 batts but i know i need a bigger alt throw another bat in back and what are your speaker wires running power n ground too
Well, you are running alot more power than me, so I understand your need for a better alt
Speaker wires are 8 gauge ofc Audio-Technix
Power wires are Cadence 4 gauge wire from this kit I got a long time ago
http://www.ebay.com/itm/Cadence-WK41-4-Gauge-Complete-Car-Amplifier-Installation-Kit-Amp-Wire-Kit-/300712933776?pt=US_Car_Audio_Video_Amplifier_Kits&hash=item4603e33990
wouldnt this mean u need more battery?
I know it probably does, but I want to make sure it's another problem
2003 Kia Sorento
Team Subsonic Lows
55-100 amp alt??? You mean you have 55 @ idle and 100 max. That´s a tiny alt, if your car is running and use some voltage for his own electrical and you draw on music
50-70 amps, so it realy start to suck you batt quick.
It looks like itaht you have the 90 $ batt out of the offer in the "Hot-deal´s" section, add a second batt. Or get a 150 amp + alt, + depend´s more what you want to do in the future
"in the abundance of water, the fool is thirsty" Bob Marley
http://www.ebay.com/...=item4603e33990
is your fuse from a long time ago as well?
**actin bad like a kid at six flags**
Yeap, still using it cause it hasn't blown or anything
Friend of mine told me that it could be my power being too small causing it to drop badly
Might as well save up for it then.
2003 Kia Sorento
Team Subsonic Lows
Are you holding the throttle at about 2,000 RPM? You do not get full alternator output until you are around 1800-2500 engine RPMs. It might only be able to put out 40 amps or less at idle.
Need Test Tones/Sine Waves? Click Here!
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Pioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE Audio
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Hit me up on Facebook, if you want
I was revving it to 2k when I was recording
2003 Kia Sorento
Team Subsonic Lows
  • Who's Online   0 Members, 0 Anonymous, 1466 Guests (See full list)
