Can a bad power wire cause bad voltage drops at the amp?
So quick question, can an alt go bad after years of use, mine being 15 years old?
Though at the meantime, I'll save up for a second battery, get power wire since I need some for my highs amp anyways, and see what happens. I'll take it easier on the electrical, don't need to play full tilt often anyways, happy with lower volumes for now.
Thanks for the advice guys
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Where did you get the power source from for the volt meter? On those, the B+ cable that goes from the battery to the fuse box corrodes badly at the fuse box. Its four 10g wires in a loom going from the batt to the fusebox. On yours, its the cable with the wingnut on the positve terminal, and also appears to be stock/factory.
Voltmeter is reading and powered from the amp. It's a simple red and black wire voltmeter with the switch on the red wire to turn the voltmeter on and off
I sanded down the fuse box cable, and soldered it to a ring terminal cause I broke the tip when trying to drill a bigger hole on it.
When I did the Big 5
I did
Bat - to frame
Bat - to alt frame
Bat - to engine block
Bat + to starter solenoid to Alt + (stocking wiring was like that with the stock 4 gauge wire)
Bat + to Alt + directly (advised by Mike Singer to do)
2003 Kia Sorento
Team Subsonic Lows
Pull the cover off and look at the copper in the cable. see if it is corroded. If so replace it. This will also cause other electrical issues in your car, trust me
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
What cover?
Though I did sand sand down the corrosion off till I saw bare clean copper, then soldered it in my ring terminal. Everything in the car works, all the lights, and switches work, all the fuses are in good shape, and not blown. Only thing that doesn't work is the speedometer but that's a different problem on its own.
2003 Kia Sorento
Team Subsonic Lows
its your alt. so start saving for a h.o alt. but also its good to charge your battery every now and then so try to get a charger soon. i suggest charging your battery at a low amperage for a day or two and that should help, upgrading your 4 gauge power wire to 1/0 will also help out.
2000 Dodge Durango
Subs - (2) SKAR VVX 15 D2's
Box - 7.2 ft^3 @ 33hz, 120 in of port
Sub amp - Digital Designs M2 @ .5 ohm
Mids + Highs - PRV Audio
Mids + Highs amp - Hifonics 2000.4
Headunit - Alpine CDE-100
Equalizer - Clarion EQS746
Batteries - Mopar group 27 + (2) C&D 52ah
Wiring - 1/0 BIG 3, (2) runs 1/0
Alternator - Singer 250A
147.79 dB @ 35hz - burp - sealed on dash
147.47 dB @ 35hz - music - sealed on dash
YOUTUBE: http://www.youtube.com/user/321slapinBass/videos
Gonna start saving for the 260 amp Singer alt I want
1/0 gauge won't fit lol but I'll upgrade to AT ofc 4 gauge, which is alot better than Cadence
2003 Kia Sorento
Team Subsonic Lows
I do have this laying around, Dogfret gave it to me, since he told me he used to drive the same car as me, except it's a T5
How mine sits
Should I just swap it out, or leave it be, and take it easy till I get my HO alt?
2003 Kia Sorento
Team Subsonic Lows
the longer u have been beating on it the better chance that its going
i think most advance auto parts do free alternator testing
if u plan on getting those 15's and aq2200 soon then hold out for the singer alternator
otherwise a simple alternator replacement should be enough for the amp your running
i would def try that extra alt u have if it fits
why not? looks like a good car audio fix
**actin bad like a kid at six flags**
  • Who's Online   0 Members, 0 Anonymous, 481 Guests (See full list)
