Box design help with port length (Torres and SketchUp inside)
Skrilla
what sub and how much power
and you still need to tick up/up
edit
what car? 60" width is near impossible for most
HDC318's on an AQ2200.
It's for my dodge ram.
With 2 common walls and same box height and same 10 inch wide port you can only go 14 inches long.
Wait, I thought I could go up to 18.99" on a 2 common, and up to 13.99 on a 3 common? If my port is 17" long on a 2 common, that leaves 7" from the bottom.
2 HDC3 18's
AQ2200D
why is this
a 2 common wall port splits into 2 port to create a T-port
and in doing so the width changes to 5" across the back
at 18.99" long there is no L2 and that is the length of the port
at 19" the L2 is 0.75" (port wall thickness) giving you a port length 24.75"
so 19"-24.75" is a non achievable port length
Really, did you look at his design, he isn't doing a T shaped port.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
The port opening has to constant throughout the entire length, so your port is 10 inches wide, that means the leg of the port can only go down 14 inches, in your case 12.5 since your baffle is 1.5 inch thick being part of the port length. That would put it 10 inches from the back wall of the box making the opening and exit of the port the same which they have to be.
Evo X build log
his first drawing was side port (*3 common wall)
if he does a centre port (2 common wall)
a 17" port length is doable (an L1 of 15.5)
giving him an opening of 7" on both sides, equal to the same as 14" of opening
So can anybody else confirm this? I'm just a little confused with getting two different answers...
I know I can't go closer than 10" from the back wall on a 3 common port, so does that mean I can go up to 5" deep, each side, from the back wall, with a 2 common port, which is equivalent to 10"?
2 HDC3 18's
AQ2200D
  • Who's Online   0 Members, 0 Anonymous, 877 Guests (See full list)
