From_the_Valley Posted December 30, 2012 Report Posted December 30, 2012 Ok so I have a sax100.4 on the way and eventually a saz.1500 or 2000. First question is can I use one 0awg power wire to a distribution block to power both of these or should they have their own power and ground wires? Second is what size inline fuse would I need on that power wire? And would I need to upgrade my electrical system at all like the big three or a ho alternator? (2005 Titan)
graham0599 Posted December 30, 2012 Report Posted December 30, 2012 I personally would run separate power wires to each amp. Fuse is just based on the manufacturer specs, so probably around a 70amp & a 150amp. Definitely should do the big 3. What size alt is the stock though? My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678
From_the_Valley Posted December 31, 2012 Author Report Posted December 31, 2012 Ok I'm just trying to figure out how to hook up the wires to the terminals. I don't have to run the ground all the way to the battery right? Just to the chassis? For now i just have a 300 watt amp to my subs. And the stock alt is 130 amps.
CNF Kevosinn Posted December 31, 2012 Report Posted December 31, 2012 defiantly run separate wires and do the big 3. If you get a good battery for under the hood you should be fine with the 1500. If you go with the 2 k I would think about adding a second battery in the back of the car *** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ ) "kevosinn's" astro van 8 custom Sundown Zv4 18's 4 Sundown scv 6000's CNF Distribution CNC parts Skyhigh wire some batteries SMD Meters and tools used on the installhttp://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/ 16,000 watt walled silverado build.http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/ 8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60TEAM CNF Distribution
beaker Posted December 31, 2012 Report Posted December 31, 2012 I would upgrade, with electrical there's no real harm in overdoing it. I have a 200 amp breaker on a 4x100 kenwood and a 1x1200 Hifonics Brutus, it seems to hold up fine. I am installing a second battery though, because even with an alt upgrade (220amp) and one run 0awg, I still get voltage drop. Though that could just be I have a bad ground too.
From_the_Valley Posted December 31, 2012 Author Report Posted December 31, 2012 Appreciate the input guys. Now where to put that second battery hmmm...
