Skullz Posted December 31, 2012 Report Posted December 31, 2012 If you can try the subs with a different amp to make sure that they work to try and eliminate them from being the possible cause. You will need to go through all the wiring to find out where your losing signal from, could be a bad terminal connection or something else. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Humbol Posted December 31, 2012 Author Report Posted December 31, 2012 i did that battery test with the subs it made noise. lol im feeling its the amp 89 Toyota P/U Single Cab HU - Kenwood x-396 Front Stage - Kenwood KFC-1094PS Rear Stage - Kenwood KFC - 6984PS Sub - Alpine SWR 823D Amp - Alpine MRP M500
Pioneerchuck Posted December 31, 2012 Report Posted December 31, 2012 It sounds like its the amp, a couple years ago I had this happen to a PA amp I was using. But go ahead and check the connection to the deck and then check the RCAs and make sure they're all good before you single out the amp.
