FamilyB4Others Posted January 2, 2013 Report Posted January 2, 2013 Well my alternator just took a crap today. Only pushing 1300 watts with some leds. Do I really need a HO alt? Should I buy a stock one at AutoZone for 120.00 and return it every time it craps out or 550.00 for a HO alt with only 2 yr warranty? Ps i got a second battery also.
wcefai Posted January 2, 2013 Report Posted January 2, 2013 You should be fine with big 3 and that second battery. I'd say just get a volt meter and make sure you aren't dipping too low Edit: can't type
SnowDrifter Posted January 2, 2013 Report Posted January 2, 2013 The real question is what voltage do you drop to? I wouldn't thin you should need an h/o alt for your system. But every car is different. I'd get the AutoZone one for now. Do you have access to a dmm? Get your alt installed, start the car, drive it around for 10-15 minutes then stick your probes from the dmm on the battery and see what your voltage is. Then turn your system up and see what it drops to ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Tarball Posted January 2, 2013 Report Posted January 2, 2013 What type of car? What does your stock alt output ? If your stocker is way under your amp usage you may need a HO alt even at just 1300 watts. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
FamilyB4Others Posted January 2, 2013 Author Report Posted January 2, 2013 You should be fine with big 3 and that second battery. I'd say just get a volt meter and make sure you aren't dipping too low Edit: can't type Hopefully as I'm dead broke to to the holidays and cant afford the HO alt. The real question is what voltage do you drop to? I wouldn't thin you should need an h/o alt for your system. But every car is different. I'd get the AutoZone one for now. Do you have access to a dmm? Get your alt installed, start the car, drive it around for 10-15 minutes then stick your probes from the dmm on the battery and see what your voltage is. Then turn your system up and see what it drops to Ever since I did my installed, I never did check voltage drop since lights never dim or bass issues. I do have a ddm, ill do the test when I get the alt. What type of car? What does your stock alt output ? If your stocker is way under your amp usage you may need a HO alt even at just 1300 watts. Its a 2005 acura tsx, im thinking arounx 80-100 amps
Tarball Posted January 2, 2013 Report Posted January 2, 2013 Well, since your alt is dead and I assume you need your car I advise the following: Get the autozone alt to get you up and running at the least. Do the Big 3 while you change the alt - use all 1/0 OFC -do not remove existing wire, add to it. Set your gains so that you are not clipping the @#$% out of your music. Monitor voltage as indicated above. Make additional upgrades as appropriate. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Watch the bass Posted January 2, 2013 Report Posted January 2, 2013 Who give you the quote for the H/O alt and did you quote all the wll known brand´s, DC power, Mechman, Singer...? "in the abundance of water, the fool is thirsty" Bob Marley
FamilyB4Others Posted January 2, 2013 Author Report Posted January 2, 2013 Well, since your alt is dead and I assume you need your car I advise the following: Get the autozone alt to get you up and running at the least. Do the Big 3 while you change the alt - use all 1/0 OFC -do not remove existing wire, add to it. Set your gains so that you are not clipping the @#$% out of your music. Monitor voltage as indicated above. Make additional upgrades as appropriate. 1. Will do 2. Done already but used cca...1300watt didnt think i really needed OFC. 3. Already done with a DD-1 4. Will do Who give you the quote for the H/O alt and did you quote all the wll known brand´s, DC power, Mechman, Singer...? DC awhile ago but they are having a sale right now 479.99 plus 17.99 shipping
Watch the bass Posted January 2, 2013 Report Posted January 2, 2013 Well, since your alt is dead and I assume you need your car I advise the following: Get the autozone alt to get you up and running at the least. Do the Big 3 while you change the alt - use all 1/0 OFC -do not remove existing wire, add to it. Set your gains so that you are not clipping the @#$% out of your music. Monitor voltage as indicated above. Make additional upgrades as appropriate. 1. Will do 2. Done already but used cca...1300watt didnt think i really needed OFC. 3. Already done with a DD-1 4. Will do Who give you the quote for the H/O alt and did you quote all the wll known brand´s, DC power, Mechman, Singer...? DC awhile ago but they are having a sale right now 479.99 plus 17.99 shipping Ask Singer and Mechman, Singer is often the lowest offer! "in the abundance of water, the fool is thirsty" Bob Marley
