help me port my box
dee242
i know ported nox is going to be bigger but i dont have any max dimentsions really but ok LENGTH=25 HIGHT=17 WIDTH= 35
Cut sheet is listed on the pic, but since Torres isn't calculating ports correctly the side with the port on it will be 15.5" X 24.24", the front piece where the subs will be mounted will be 15.5" X 25.25", the port piece will be 15.5" X 19.5", and the Port Extension Piece will be 15.5" X 22".
Make sure you glue all joints with wood glue, use screws spaced at least every 3" and at least 2" away from the ends, and use caulk when done around all the inside joints. These measurements are based on the use of 3/4" thick wood, you should use MDF board, you can get it at lowes in a 4'X8' sheet for around $35. don't use sheetrock screws.
You're welcome
25d9cf71-fff8-4b67-a8f5-28c80d5ea859_zps7d3fe7f6-90c4-4939-b709-43f0e5812212_zps
2018 Honda Civic Sport Hatchback (build in progress)
NVX Sound Deadener (Front Doors)
Stinger FAST Rings
Stock Electrical
SSA Evil 6.5's Front Speakers
Stock rear speakers
MB Quart ONX4.80 speaker amp
Rockford Fosgate T-1500bdcp
DC Level 4 12" D1 @ 2-ohm
Box In Design Stage
Stock Radio
My Build Log
oops, forgot to upload the box design
Stinger FAST Rings
Stock Electrical
Stock rear speakers
Box In Design Stage
Stock Radio
My Build Log
sorry guys, lol, I just got home from both jobs and slapped that message together, box dimensions are correct just need to cut 2 holes out for the subs, not that big of a deal
Stinger FAST Rings
Stock Electrical
Stock rear speakers
Box In Design Stage
Stock Radio
My Build Log
  • Who's Online   0 Members, 0 Anonymous, 932 Guests (See full list)
