I don't like the look of 26s on the OBS tahoes but that's just me. I have 22s and wish I whould have gone 24s .
If you do get 26s I think you'll run into rubbing issues
Alpine 9884
RF T2 comp set up front
The Epicenter
2x RF T10001bd
2x Sundown sa-15 t-line
Big 3
Smd DD-1
Im a huge fan of 26s but unless you wanna spend some time cutting at the wheel wells to avoid rubbing, Id say go with a set of 24s. They look good on the old body styles and they don't rub as bad as the 6s would. You might wind up with just tad bit, Im not sure though.
I have 26" on my 97 & they barely rub on my front plastic fender flares....if the fender flares weren't on then nothing would rub... & I mean barely rub
H/U Pioneer deh80prs w/ HRT iStreamer Ipod DAC
Front stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweets
amp running 4mids, Mosconi Audio 300.2
amp running 8tit & alum tweets, Mosconi Audio 200.2
8 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'z
box is a 4th order band pass
batts. 1 XS Power D3400 under hood,6 D3100 in back
2 XP 370 amp DC Power alts.
MLA module 15+volts
All in a 97 2door Tahoe LT
2010 West Coast Reg. 140-149.9 Bass Race Champ
Team Bass Hz
ive seen plenty of those body style tahoe's with 26s and not much if any cutting was done
i say go for it, you go with 24s and youll get tired of them real quick and wonder why u didnt go bigger
i wanna say s 9.5 or 10in wide wheel will work
tire size a 305/30/26 should work
youre gonna need to run bands. ill take a pic tomorrow when i go outside and show you what my 305.35.24s look like in the wheel well and how close it is. So you can then use the outer diameter from my measurement to gauge what size tire to run.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
you wont fit a 26 inch 35 thats for sure. You may need to go to a 25 to be honest. 30 may work. so a 25 or a 30 are your only optionts.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
