bass_stalker Posted January 7, 2013 Report Posted January 7, 2013 what do i need to look at when choosing a graphics card? i know you need the correct slot type but what are the other specs that matter? currently working with this JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
n1ghtsn1p3r Posted January 7, 2013 Report Posted January 7, 2013 See if your PSU has enough wattage to handle the one you want. A lot of prebuilt PCs don't including that one. Yours only has a 250 watt PSU. 2016 Ford Focus SE No build log yetDC Audio 1.2K2x DC Audio Level 2 10"
bass_stalker Posted January 8, 2013 Author Report Posted January 8, 2013 See if your PSU has enough wattage to handle the one you want. A lot of prebuilt PCs don't including that one. Yours only has a 250 watt PSU. upgraded to a 520 watt a while back. i'm just curious if there is a specific size card i need memory wise JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
boom50cal Posted January 8, 2013 Report Posted January 8, 2013 What brand 520w? Link maybe? A used Gtx 570 or a new 7870 would run well on a good 520w. My 570 runs on a thermaltake TR2 500w. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
Skrilla Posted January 8, 2013 Report Posted January 8, 2013 What do you plan on doing on this PC? General use, gaming, etc. 2 HDC3 18's AQ2200D
bass_stalker Posted January 8, 2013 Author Report Posted January 8, 2013 youtubing and light gaming, i just got into garrys mod and i'm running at 16fps at most points JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
bass_stalker Posted January 8, 2013 Author Report Posted January 8, 2013 i'd have to drop the power supply out of the case to see what brand it is, i thought i had the box somewhere but apparently not JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Skrilla Posted January 8, 2013 Report Posted January 8, 2013 If you're looking for something cheap, then this will work good and is cheap http://www.newegg.com/Product/Product.aspx?Item=N82E16814130841 It will be able to play any game out, just not on high settings. It will be fine for light gaming. If you have a little more you want to spend, then I'd look into the GTX 660 or 670 2 HDC3 18's AQ2200D
Kingcuong5o4 Posted January 8, 2013 Report Posted January 8, 2013 Make sure to keep your driver updated I just updated mi e and the score went from 4.3 to 6.1
P4killer_ Posted January 8, 2013 Report Posted January 8, 2013 Also if you a big box rig. The case size is a factor. Some of those bigger cards won't fit size wize. Measure to make sure. Most of those big box cases are mini atx and usually have HDD cages or fan shrouds in the front bottom of the case that can seriously limit your room. Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
