Hey guys, I'm looking to upgrade from 2 rockford fosgate punch p1s, and a "1200w Sony amp" to something better.
I was thinking about 1 sa12, ported. But i was told i dont have enough depth.. 6-8inchs. and that would be on the passenger side.
So i plan on getting 2 sd2-12s [D4 model] - from sundownonly.com
http://www.sundownon...-sd2-12-dual-4/
and run them off of this amp @ 4ohm or 2? :twirl:
http://audioque.com/...ifier_p_30.html
My lights dim a little with the shitty set-up i have now so i also want to get a big 3 kit. i was looking at this one:
http://www.ceautoele...m/big3kits.html
I drive a 2000 s10 xtreme, single cab. So i dont have any room at all. Its a daily driver (mostly night since i work the graveyard shift at UPS)
i'm not looking at numbers or anything.. i just want something that sounds good and hits hard.
Is there any other good amps around my price range of 250-300$ ??
Ive been working my ass off so i can get some good equipment. so let me kno what you all think!
Thanks
Edited by DTA HONDA
2012 Ram 3500. HTT 2nd Gen manifold Swap, HTT s465 Turbo, FASS 150, 6" S&B Intake, 5" TBE, RaceMe programmer, 8 inch tip (dumped over axle) 20x12s on 35s, 6 inch lift, Color match & haloed headlights, 30" lightbar flush mounted in bumper.
2 Sundown audio SD-2 12s and a Soundqubed Q1-1200d amp.
2000 s10 xtreme *SOLD*
Run those subs at 1 ohm. That amp will be perfect for those
2004 Escalade Ext
Pioneer avh8400
Kicker ix500.4
Kicker ix1000.1
Kicker hyperflex 0+4 awg
Sundown X-15
Sundown Sa-6.5c x2
KnuKonceptz 4 channel Rca
Rockford Fosgate 2 channel Rca
SkyHighCarAudio 14awg speaker wire
Build Log
with your lack of space if you want to go ported you might oughta do a couple e8v3's. you have enough depth for them as they're less than 5" deep, and you would probably have more output with them ported rather than the 2 sd-12's sealed.
c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old.
i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer.
2003 Infiniti G35 Sport Sedan
Build in Progress
x2 I got a single E8 v3 and its awesome!!
Car:
- 2013 Honda Accord Sport 6MT
- aFe SRI
Electrical:
- Big 3 w/ Execution Audio 0/1 AWG OFC
- Stock Battery
Audio:
- JBL Power Series 6.5 Comps up front (Running off HU power atm)
- JBL Power Series 2-Ways in the rear deck (Running off HU power atm)
Subwoofer:
- Sundown Audio X-15
- CT Sounds AT1400.1D (@1 ohm)
Bedroom:
- Yamaha RX-V365
- Pair of Klipsch KG4.2's
- 2 E8v3's in a 1.34ft^3 tuned to 30hz
- No Amp yet..
- CoolMax ZU900B PSU for amp
In my room & previous car:
- Amp: Soundstream TX1.1300D @ 4 ohms (520 watts)
- T-Line Enclosure tuned to 32hz
YouTube : http://www.youtube.c...r8?feature=mhee
4 8ev3's on a saz 1200 will be loud in that truck. A set of the 6.5cs on a 125.4 running active. The big 3 kit from audio Technix along with 4ga and 8 ga kits ofc of course and a 270a alt would diffently do the trick.
1 pr Sundown Audio Sa Cs 6.5 component set
1 Sundown Audio sax 125.4
4 Sundown Audio sa8v2's
2 1500's strapped to 2ohms
1 Tenney 270 alt
Would they be able to run @ 1200 watts?
I guess i cant run them at 2 ohm, since the amp i got is a mono block.. which would've be 870
With clean signal I think they can. Make sure your gains are set correctly
2004 Escalade Ext
Pioneer avh8400
Kicker ix500.4
Kicker ix1000.1
Sundown X-15
Sundown Sa-6.5c x2
Build Log
i'm getting a dd-1, so they would be.
  • 3 weeks later...
I'm planning a rebuild to I'm thinking of 2 sd-2 10d4 in 2 seal boxes or 1 sd-2 12d2 or d4 it depends if the 12 can handle 750rms in a ported box the amp is the rf t1000bd
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
  • Who's Online   0 Members, 0 Anonymous, 645 Guests (See full list)
