Rockford96 Posted January 8, 2013 Report Posted January 8, 2013 Im relatively new ti car audip been researching and stuff for about 2 years but have only done 1 real install and 2 just sub and amp but my question is what is running active? On like tweets and what not im just tryin to understand what it means/does thank you guys in advance. I prob wont be on again until late tonight so i wont be able to reply but thanks for helpin me out My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
tacomaguy1 Posted January 8, 2013 Report Posted January 8, 2013 component sets will come with a crossover, the mid and tweeter connect to the crossover then connect to the amp with running active you wouldn't use the crossover that came in the set and hook up the mids and tweeters directly to the amp. Then you would use either the headunit, amp, or some sort of processor to set the crossover points for the mids and tweeters individually Team Flex Issues
BEEMDUB Posted January 8, 2013 Report Posted January 8, 2013 http://sound.westhost.com/biamp-vs-passive.htm
MrSkippyJ Posted January 8, 2013 Report Posted January 8, 2013 Technically speaking, active vs. passive refers to anything having its own power supply vs. using power from something else. Active crossovers have their own power, and allow you to control the crossover before the signal is amplified. Passive crossovers use power from the output of the amp and you have no control over the signal before amplification. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Rockford96 Posted January 8, 2013 Author Report Posted January 8, 2013 Ok thank you guys that makes 1000X more sense ive been wondering that for a while now just never seen anywhere on here that explained it thanks again guys My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
