Aaron813 Posted January 30, 2008 Report Share Posted January 30, 2008 Here is a rough sketch i just did yes you can just run one from the front battery if you want to but make sure that you have a very good ground for the back battery Quote Link to comment Share on other sites More sharing options...
loganberry Posted January 30, 2008 Author Report Share Posted January 30, 2008 Here is a rough sketch i just did yes you can just run one from the front battery if you want to but make sure that you have a very good ground for the back battery so even if i run the ground to both batteries, i should still ground out on the frame rail on the back one, and will those 2 200 amp fuses work? Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk Link to comment Share on other sites More sharing options...
FieroGrande Posted January 30, 2008 Report Share Posted January 30, 2008 I think thats the same seller that bill got the 4/0 wire from for his wifes truck. Quote Link to comment Share on other sites More sharing options...
loganberry Posted January 30, 2008 Author Report Share Posted January 30, 2008 I think thats the same seller that bill got the 4/0 wire from for his wifes truck. will 2/0 be good enuf for a rockfor t1k and a rockford 800.4 and for the big 3 and for the xtra battery? Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk Link to comment Share on other sites More sharing options...
Aaron813 Posted January 30, 2008 Report Share Posted January 30, 2008 Ya you will still need to ground the rear battery and i think that those fuses will be big enough but it all depends on what wire you end up getting here is another wire thats cheap and isnt as good as the Knukonceptz fleks but is going to be bigger than the 1 gauge welding cable you have posted Klm this can use up to a 250 amp fuse Quote Link to comment Share on other sites More sharing options...
loganberry Posted January 30, 2008 Author Report Share Posted January 30, 2008 Ya you will still need to ground the rear battery and i think that those fuses will be big enough but it all depends on what wire you end up getting here is another wire thats cheap and isnt as good as the Knukonceptz fleks but is going to be bigger than the 1 gauge welding cable you have posted Klm this can use up to a 250 amp fuse so the knu 1/0 is better than the welding 2/0? Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk Link to comment Share on other sites More sharing options...
Aaron813 Posted January 30, 2008 Report Share Posted January 30, 2008 Well the welding cable is going to be a true 2/0 the Klm wire is copper and aluminum if you arent wanting to spend alot on wire then i would say to go with the welding cable but the klm 1/0 would also work fine Quote Link to comment Share on other sites More sharing options...
kingsuv Posted January 30, 2008 Report Share Posted January 30, 2008 so the knu 1/0 is better than the welding 2/0? I wouldn't say the Knu stuff is any better. It's tinned copper not 100% like the welding stuff is. I just ordered 100FT of 4/0 from Coppercableman. Quote Designing, building, and shipping boxes. Yahoo IM - kingsuv00If the listening level is too loud, please inform the driver, so he can promptly pull over, and let you out. not many cars can get me to pluggin my ears but this one.......damn. I mean the first minute is ok but that thing just really starts digging deeper and deeper in your earhole till you cant stand it no more. Seems like it does it with relative ease....16 12's on 8 amps.........gotta love it. Link to comment Share on other sites More sharing options...
loganberry Posted January 30, 2008 Author Report Share Posted January 30, 2008 (edited) I wouldn't say the Knu stuff is any better. It's tinned copper not 100% like the welding stuff is.I just ordered 100FT of 4/0 from Coppercableman. ok, i dont think i wanna go that BIG how will the 2/0 work in my situation for what i need? Edited January 30, 2008 by loganberry Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk Link to comment Share on other sites More sharing options...
Aaron813 Posted January 30, 2008 Report Share Posted January 30, 2008 with 2/0 you should be fine Quote Link to comment Share on other sites More sharing options...
