loganberry Posted January 30, 2008 Author Report Posted January 30, 2008 with 2/0 you should be fine ok thanks, and is there like a strong slim battery any1 knows of i can fit under the seat of my truck? i dont have room behind the seat or really anywhere else, thx Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
Aaron813 Posted January 30, 2008 Report Posted January 30, 2008 (edited) Well for that i would recommend this its small and is really strong hell i even have one in each of my quads this check out the stats on that one if not they have ones that just get bigger from there Edited January 30, 2008 by Aaron813 Quote
loganberry Posted January 30, 2008 Author Report Posted January 30, 2008 Well for that i would recommend this its small and is really strong hell i even have one in each of my quads this check out the stats on that one if not they have ones that just get bigger from there can i lay that down? and will 1 of those, with my stock battery and alternator be ok? if i use the 2/0, do big 3 and yea yea Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
Aaron813 Posted January 30, 2008 Report Posted January 30, 2008 What kind of battery do you have stock it should be enough if for some reason it isnt enough you can put a Kinetik 1400 or whatever will fit up front but you should be just fine Quote
loganberry Posted January 30, 2008 Author Report Posted January 30, 2008 What kind of battery do you have stock it should be enough if for some reason it isnt enough you can put a Kinetik 1400 or whatever will fit up front but you should be just fine its stock battery, stock alternator, if my lights dim with the 2nd battery then i can just upgrade the front battery, and if that dosnt help, a better alt should Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
Aaron813 Posted January 30, 2008 Report Posted January 30, 2008 Ya i think you should be fine with just that back battery Quote
loganberry Posted January 30, 2008 Author Report Posted January 30, 2008 Ya i think you should be fine with just that back battery ok, and can that battery lay down on its side, i just looked, i dont have room for it to stand up, so i would have to lay it down and hope it fits Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
dmanson Posted January 31, 2008 Report Posted January 31, 2008 ok, and can that battery lay down on its side, i just looked, i dont have room for it to stand up, so i would have to lay it down and hope it fits definitely go with the kinetik, you should be able to lay any of those down. Quote 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
loganberry Posted January 31, 2008 Author Report Posted January 31, 2008 definitely go with the kinetik, you should be able to lay any of those down. ok, thanks! Quote My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
Aaron813 Posted January 31, 2008 Report Posted January 31, 2008 I would hope they can be laid down because i jump 20 ft in the air side ways and shit Quote
