Hyundia Tiburon 01 - Alternator Questions
Take a look at my "garage" to see what my setup is so you are more familiar with my system.
Anyways, I have my Rockford Fosgate T1500.1bdCP and a Pioneer GM-D9500F 800W RMS amplifier. I am just wondering if I should get a new alternator If so, how many amps.. And where may I be able to find this alternator..
I have a Hyundia Tiburon 01.
Thanks ahead of time.
If you have further questions, feel free to drop a comment below..
My trip to Meades shop - http://www.stevemeadedesigns.com/board/topic/172904-could-i-come-for-a-visit/
My vid at Meades shop - http://www.youtube.com/watch?v=YxinD-xwWWo
Had an amazing time bro! Die hard Meade fan!
-- My System -- 2001 Hyundai Tiburon --
(1) Rockford Fosgate 1500.1bdCP
(1) Rockford Fosgate 360.3
(1) Pioneer GM-D9500F
(1) Optima Yellow Top D34/78
(2) Pioneer TS-W3002D - 1000W RMS 12's
(1) iPhone 5s - 32gb White
(1) iPad Mini - 16gb Black ( 24/7 Headunit )
-- Wanted Upgrades --
(2) SP4 (15's or 18's)
(1) BC5500
(1) Mechman 320 amp Alt
(4) Optima Yellow Top D34/78
(1) Big 3 Upgrade Kit
Fix my other T1500.1bdcp
It definitely wouldn't hurt to get a battery under the hood sometime soon. As far as the alt goes, it all depends on the alt you have in the car. If you upgraded battery to a good beefy group 31 battery and kept the stock alt then You would be fine as far as running that amp in that car.
  • 5 months later...
If u haven't found one yet I got a 320 amp one from Ohio generator worked for me only had to do some slight modifications grind part of it down and longer belt and had to take off belt tensioner.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Did you have it in a Tiburon?
And I've done some upgrades to the system sense this post.
I now have 2 t1500's and my 800 watt amp for the doors.
I also have ran some 1 awg from front to back and added a Optima Yellow Top in the back.
(1) BC5500
Yes a 97 Tiburon fx. barely anyone makes ho alternators for Tiburons.
Youshould of went with blue top optimas if u where going with that brand xs power I have heard hold voltage a lot better. I'm going to save up for a d3400 underhood then eventually 2 d3100 for the trunk when I save up and run my 4 skarr vvx 12s and a sk4500 will be sweet evently.
The bdcp pull a good amount of power. Fuae rating for the 1500.1 is 200amps. If you alt is 170 or higher I would do the big 3 and under hood batt. If you arw dropping below about 13.5volts a second batt would help but an alt would be my next step. If you woild rather get an alt now look for somthing 170 or more from a company with a goos rep.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
