Water Cooled Subs (Bazooka Tri Vent)
Fast Company
STEvil, so are you saying there is a benefit here? They claim I can up the RMS by 75%... without the cooling I'm assuming it would be end of the road. I'm still hoping I run into someone here that has had these.
In the way bazooka is doing it there is very very little benefit. All of the coil cooling comes from movement in the gap and the water cooling does not provide very much cooling effect to anything other than the magnet structure.
Hammerdown... 1%
I did read few people saying that their amps became alot more stable using the chill kit. On the amp side it could be very effective if done right. I think I saw mga amps like 1100w strappable for like 110 bucks. Who knows if their any good but.Its class h/g which is always interesting . Limited voltage wise at lower imp. Limited amp wise at higher imp. Kinda cool to read about.
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
Well i'm struggling to find a used one. I wish the sub cooling was more beneficial though. I'm ruining them at 2 ohm so it's nothing spectacular but for under 300 Watts I think I did pretty good.
Yea that's decent for sure. Just have fun that's all that matters, but I didn't check.the date on those ads so who knows..
Setup:
Xs D3400/ Xs XP3000
