Water Cooled Tri-Vent Bazooka Subs.
Here is a quick description with install and a rundown of parts for the liquid cooling subs.
(for those that are curious)
Here is the pump, 2 pass through fittings for the box, 2 sub plugs, 2 tube stiffeners, and 4 amp plugs.
The radiator.
Shot of the magnet pre-plug installation.
I used some CPU heat transfer silicone on the threads of the plug to fill in any gaps between the magnet and plug.
Plug installed back view.
Plug installed side view.
Tubes installed. You can see the tube stiffener.
Water leak test. I'll tell you it's a pain trying to get a closed system air free. They really should have included a reservoir. But, no leaks and that's all that matters.
Pass through fittings in the box.
Just test fitting everything. I used some dynamat under the pump to make it a bit quieter seeing as I mounted it to the box.
Radiator mounted to the box.
Here are some videos.
Cool idea. Not so sure of the practicality (not sure how long it would hold up, or if it would really be worth it to set all this up for the amount of extra cooling).
Cool idea? Pun intended? LOL It is claimed that the RMS can be increased 75% with the water cooling. The system is on a switch so I only run it when I turn it up.
Cool!!!!
I don't care how effective or ineffective it is. At the end of the day: it's different
Well once I got the one I started doing research but couldn't find much. Kinda got me worried but it sounds pretty good. Found another on Kijiji by chance and two is definitely better than one. I'd like to find a third one and increase the power to about 600rms. If I wired three of them together and they are 4 ohms each what would that get me? 1.5?
so is the pump ran off of just a constant 12volt flow? does it have a remote start or something along the lines of that? And at maximum pumping what is the current usage?
