TheNewbie Posted January 13, 2013 Report Posted January 13, 2013 You have more room then you would think. 4 15's in a flat ported wall is doable I have a 2000 and have 2 18's in mine NOT in a wall and still had room for 8 2400's 4 3.5k's as well as mids and high amplifiers. But it is a tight fit. Your car is different than ours. Your eclipse is called a 3G. As for the 4 10s that makes a little more sense being sealed.. Not sure how you got 4 cubes tho brotha. Click the link in my sig.. That's my old eclipse 2g NA build.. You'll see how tight it was to fit a 15 in there. A 3G can't have THAT much more space than a 2G. And maybe it's because I'm on mobile but I can't find your 15 build, only the 4 8's Nah it's not THAT much different, I can't really speak for what you can fit with the seats down because personally I haven't done that. But you will be pushed for a 1 15 in back if the car with seats up. Just as a general idea, unless you fiberglass your box to fit the curves of our cars. It's right below this, ill post the linkEDIT: I didn't see bass said with the seats down, otherwise I wouldn't have commented, my appologies. Wait so where are the pictures of your 15? Here is the link, and the box pictures are in there, never purchased te 15 because I didn't think it would have enough port spacing. http://www.stevemeadedesigns.com/board/topic/136781-thenewbies-build-dc-skar-mitsubishi-eclipse-finished/page__pid__1958353__st__60 Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes.
wmrcs Posted January 13, 2013 Author Report Posted January 13, 2013 You have more room then you would think. 4 15's in a flat ported wall is doable I have a 2000 and have 2 18's in mine NOT in a wall and still had room for 8 2400's 4 3.5k's as well as mids and high amplifiers. But it is a tight fit. Your car is different than ours. Your eclipse is called a 3G. As for the 4 10s that makes a little more sense being sealed.. Not sure how you got 4 cubes tho brotha. Click the link in my sig.. That's my old eclipse 2g NA build.. You'll see how tight it was to fit a 15 in there. A 3G can't have THAT much more space than a 2G. And maybe it's because I'm on mobile but I can't find your 15 build, only the 4 8's Nah it's not THAT much different, I can't really speak for what you can fit with the seats down because personally I haven't done that. But you will be pushed for a 1 15 in back if the car with seats up. Just as a general idea, unless you fiberglass your box to fit the curves of our cars. It's right below this, ill post the linkEDIT: I didn't see bass said with the seats down, otherwise I wouldn't have commented, my appologies. Wait so where are the pictures of your 15? Here is the link, and the box pictures are in there, never purchased te 15 because I didn't think it would have enough port spacing. http://www.stevemead...1958353__st__60 Looks like you could have gone sub and port up. E34 540iT/6
TheNewbie Posted January 13, 2013 Report Posted January 13, 2013 You have more room then you would think. 4 15's in a flat ported wall is doable I have a 2000 and have 2 18's in mine NOT in a wall and still had room for 8 2400's 4 3.5k's as well as mids and high amplifiers. But it is a tight fit. Your car is different than ours. Your eclipse is called a 3G. As for the 4 10s that makes a little more sense being sealed.. Not sure how you got 4 cubes tho brotha. Click the link in my sig.. That's my old eclipse 2g NA build.. You'll see how tight it was to fit a 15 in there. A 3G can't have THAT much more space than a 2G. And maybe it's because I'm on mobile but I can't find your 15 build, only the 4 8's Nah it's not THAT much different, I can't really speak for what you can fit with the seats down because personally I haven't done that. But you will be pushed for a 1 15 in back if the car with seats up. Just as a general idea, unless you fiberglass your box to fit the curves of our cars. It's right below this, ill post the linkEDIT: I didn't see bass said with the seats down, otherwise I wouldn't have commented, my appologies. Wait so where are the pictures of your 15? Here is the link, and the box pictures are in there, never purchased te 15 because I didn't think it would have enough port spacing. http://www.stevemead...1958353__st__60 Looks like you could have gone sub and port up. You can get a 15 in there brotha, but like i said it's a tight fit man. Did that box before I was able to use the Torres. Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes.
wmrcs Posted January 14, 2013 Author Report Posted January 14, 2013 You have more room then you would think. 4 15's in a flat ported wall is doable I have a 2000 and have 2 18's in mine NOT in a wall and still had room for 8 2400's 4 3.5k's as well as mids and high amplifiers. But it is a tight fit. Your car is different than ours. Your eclipse is called a 3G. As for the 4 10s that makes a little more sense being sealed.. Not sure how you got 4 cubes tho brotha. Click the link in my sig.. That's my old eclipse 2g NA build.. You'll see how tight it was to fit a 15 in there. A 3G can't have THAT much more space than a 2G. And maybe it's because I'm on mobile but I can't find your 15 build, only the 4 8's Nah it's not THAT much different, I can't really speak for what you can fit with the seats down because personally I haven't done that. But you will be pushed for a 1 15 in back if the car with seats up. Just as a general idea, unless you fiberglass your box to fit the curves of our cars. It's right below this, ill post the linkEDIT: I didn't see bass said with the seats down, otherwise I wouldn't have commented, my appologies. Wait so where are the pictures of your 15? Here is the link, and the box pictures are in there, never purchased te 15 because I didn't think it would have enough port spacing. http://www.stevemead...1958353__st__60 Looks like you could have gone sub and port up. You can get a 15 in there brotha, but like i said it's a tight fit man. Did that box before I was able to use the Torres. Welp I'm putting 4. E34 540iT/6
TheNewbie Posted January 14, 2013 Report Posted January 14, 2013 Haha will be a blast brotha! Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes.
CstrokerV Posted January 14, 2013 Report Posted January 14, 2013 walled off behind the front seat you shouldnt have any problem doing 3 15.s .. i had one in a 3.5 cubed box after displacement behind the rear seats i cant imagine not being able to get 3 if you wall it off i might have a pic.. before i took out the seats for a different box design i had... grrr cant remember my photobucket pw lol my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
CstrokerV Posted January 14, 2013 Report Posted January 14, 2013 http://www.youtube.c...query=cstrokerv are my videos might be able to see the box not sure i miss that sub my favorite sub i have owned never got to push it to its full potential video flex 1 shows the box anyways its 3.5 cubes ported to 24hz lol my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
got160s? Posted January 14, 2013 Report Posted January 14, 2013 I have a 2g eclipse, idk if you have seen it on YouTube but I had 3 tc sounds 5100 pro 18s in mine. You can fit around a 12 cubes if you take out the backseats and use all of the area. My YouTube is got160s btw Vehicle: 1999 Chevy Suburban AKA The Bammin' Beast Battery: 25 XS Power XP1000's Sub Amp: 3 DC 9k's Sub Stage: 18 DC Lvl 4 M2 12's in a Nasty 4th Order http://youtube.com/user/got160s Subscribe now! Prizes will be given away for every 1000 subscribers!
wmrcs Posted January 15, 2013 Author Report Posted January 15, 2013 I have a 2g eclipse, idk if you have seen it on YouTube but I had 3 tc sounds 5100 pro 18s in mine. You can fit around a 12 cubes if you take out the backseats and use all of the area. My YouTube is got160s btw I'll check it out thanks! E34 540iT/6
wmrcs Posted January 15, 2013 Author Report Posted January 15, 2013 Only found a video of 2 18's E34 540iT/6
